I've been looking around for a fix almost everywhere. My bike sometimes lets me fully rev while in neutral, but sometimes not even past 11k.
When I ride with gears, it usually wont rev past 6-8k rpm and bogs down. Feels like it doesnt get enough fuel? I also installed SP Quickshifter + Launch Control kitbon this bike.
The bike hadn't this kind of issue before I tore it down before winter. I unplugged almost all the wirings and exhausts etc.
My previous post is below in there as name Coolant leak + white smoke. It had a minor coolant leak from the cooler and got fixed it by now.
However I have done the following in order to eliminate this issue:
Any ideas?
Thanks in advance!
- Disassemble the launch control kit
- Changed back the old different kind of air filter than the new one
- Borrowed a fuel pump whichs fuel filter was cleaned
- Checked ignition coils, looks fine
- 2 fuel injectors were broke, replaced them
- It also had and has C28 error due to me disassembling the 2nd throttle body (huge mistake). Took the butterfly plates off. C28 is still in there but ordered STV Eliminator kit
- Spark plugs seemed to be fine. A mechanic said it sounds normal and it does
- Checked for air leaks, didnt seem to find any
Any ideas?
Thanks in advance!
