killswitch housing?!?! nah..dat sounds too simple...gimpsta said:wow i always just called it right clipon wiring assemblyor killswitch housing
not sure, maybe if you got the 1k's you could swap the map modes with the ECU and do ludcrious speed!
.Avplayer said:killswitch housing?!?! nah..dat sounds too simple...now onto the k7 1k idea, hmmmmmmmm, might hafta try that :lol althought i doubt it'll be a direct bolt on :hammer
So I figure if an 03 1000 can take an 04 600/750 throttle housing, then its gotta be possible to do it the other way.2003-2004 Models do not allow full lock steering to the right with stock steering stops due to the throttle cables contacting the ram air tube. Racers need to either 1) build up the steering stops, 2) rotate your throttle tube couterclockwise or 3) adapt 2004 GSXR 600/750 top exit throttle housing
