1 - 2 of 2 Posts
CHEC
It means the cluster isn't receiving serial data from the ECM. This happens when the ignition switch is on and the kill switch is off. It's also caused by a fault, typically at a connector, on the B/G lead from the ECM to the cluster.
1 - 2 of 2 Posts
