Okay so I got a 06 gsxr 750 I just got done putting the motor back in but when I go to see if the motor will turn over the ecm is clicking and nothing else. The starter is getting power still. Also on the throttle body, the secondary butterflies on initial turn key will open about half way, jitter and then close again. Any help will be much appreciated
· Dreaming of buttsecks for years...
The ECM doesn't click. You're probably hearing a relay near the ECM. The behavior of the secondaries suggests that the sensor is bad or incorrectly installed/adjusted.
okay did some more digging. So it’s clicking where starter wire/harness and positive wire connect. Fuse is good. I am running like 11.4 volts so I’m going to charge it up and see again but I got a new stva and still having the same problem with those butterfly’s just not opening properly and closing back on itself. Thoughts? Much appreciated🙏
