Well, you're hooked up to the STPS, not the TPS. And I can't make heads or tales of how your probes are wired. You've got something hooded to the wiring harness. If you're checking resistance of the sensor, you should have it disconnected from the harness, and your meter should make connections to the sensor and nothing else.
