461 - 477 of 477 Posts
I see that I wasn't paying attention. Per 10-53 in the service manual, all drive plates are 2.8 ± .08 mm thick. That means that the stack height is 10*2.8 + 9*2.3 = 48.7 mm (1.917 in) when a 2.3 mm ninth driven plate is used. The ±.3 mm ninth driven plate option may be to allow that height to be achieved when the drive plate variations stack up. At least that's the best that I can come up with right now.
I can add that to the K5/K6 service manual if a fairly broad consensus can be reached here. However note that this is for a new clutch. Used drive plates can be much thinner and I don't know what to do about stack height there.
Finally, in partial answer to DutchGSX-R1000's question from five months ago, the OEM spring free length is 57.01 mm and they should be replaced at 54.2 mm. His winding counts seem reasonable when compared to spring pics but I can't be more specific than that. No idea of wire diameter. Coil diameter is also important but it can't vary much, given the constraints of the head.
Just bought my first GSXR a K5 1000 rizla 9k miles but on the way home I found it judders like a bitch in first sometimes so here I am.
Has anyone got the PDF of this mod as the resolution on the pics aren’t great. I fancy giving it a go.
Cheers
I've read practically every K1-K9 clutch post there is in an effort to satisfy my K4 clutch OCDness.
This is my first road bike K4 1000, when purchased it had 16,000km and had been fitted with the Kawa plate and was smooth on take off but that was it. Crunched when changing up and down gears, changed the oil to Amsoil and it was 30% better.
Then I removed the clutch and found it was dry, lubed plates was better for a while, removed basket and drilled 3 holes.
Better again but it still felt like the clutch wasn't fully releasing. Also when changing gears and releasing the throttle it felt the like engine braking was slowing the revs down too much and just the engine braking in general was too much (I ride two stroke dirt bikes) had to keep a little throttle on. Clicking from 2nd to 3rd was real clunky.
So I bought a low mile K8 complete clutch assembly. Ordered a new K5-6 lifter hat to fine tune rod length and a new gear selector star.
I drilled 3 extra holes in the basket and fitted everything this week, still on Christmas holidays?. Set slipper adjustment to 2 turns out.
Did a 200km test ride today and it's a different bike! Snicks gears no crunching. 2nd to 3rd great now shifts smooth. No engine braking effect on gear changes, I can pop down through the gears and the bike stays calm almost feels two strokeish running through a turn, one small down side is I have to brake harder to compensate for lack of engine braking! So happy with the bike now, one happy camper!
Thanks again for all the great information.
Next job is to re-valve and spring the rock hard forks.
I was just reading the 2007 New Model Update Seminar Manual and it mentions that the eighteen oiling holes in the side of the clutch hub were enlarged from 2 mm in K5/K6 to 3 mm. This seems like a simple thing to do while the clutch is apart. Has anyone done that or have any opinion pro or con about it?
^Search the K5/K6 forum for "clutch chatter". Look for posts that are at least 10 years old. Many of the hits are in this thread. It happens during moderately hard launches.
ON mine, it happened just taking off 90% of the the time. Chattered is a pretty good descriptive term i guess.
I just replaced the conical washer listed (from a 750?) and now I get ,chatter less than 1% of the time.
