I sat on the parts since October. It is truly only a 3 or 4 hour job if you don't take breaks.I've had the parts sitting since last summer, I better get on this.
Here is my DIY contribution this great site. This is the clutch mod that has been discussed in the past. Thanks to Stocky for his contributions and others.
I have the PDF also for anyone interested to download here is the link Below. 56k users this is your best OPTION. Also if it expires pm me with your email and i will send it out.
http://www.savefile.com/files/636359
Enjoy!
-Ali-:cheers
QUOTE]
Jetspeedz
I had a question about adjusting the 3 pressure plate screws in the last step. You said to loosen the nuts and turn the screws all the way in until they bottom out. I wasn't quite sure what all the way in was. I turned mine in and you could feel when they first touched, but they would keep turning. As I kept turning you could see the pressure plate gradually move out. How far in are you supposed to screw them? Until they go all the way and eventually stop? Or to that initial contact before the pressure plate starts to move out? Or screw them in until they are flush with the nuts? I wasn't sure just how far to turn them in. I turned them until they first touched, but then it got a little harder as the pressure plate moved out but I could have kept turning them? Did I stop too early? I stopped when the pressure plate started moving out? I don't think I'm getting any slippage at all so I was wondering it I stopped too soon? I still have about 3 threads showing. And I measured the distance with a digital caliper before and after. THe same exact amount of threads is showing now as before the mod(2.9mm on the caliper). If I kept screwing the bolts in, would the pressure plate finally have bottomed out? Looks like that would have caused it to slip too much, since there would be no pressure on the clutch discs. Thanks for the help!
Performance wise is all subjective, i suppose if you like to launch the bike hard of the line its an upgrade and for the avg street rider it only improves the clutch performance if you do the mod and drill the holes for extra lubrication.hi ,first thnx for taking da time to do it .
i want to know what differnce will come in clutch performance after this mod ?
Diesel its very easy. Tighten down the screw until you feel resistance, if your turning it in past the resistance point yes you will move the basket and you will cause the clutch to slip and not engage at all.SPL,
Had a question about how you were adjusting the clutch screws on your clutch mod. When you turned them in, how far did you go? I can't figure out from the instructions if I've turned them in far enough? There is an initial point of contact? Stop there? Or keep going until it finally won't turn anymore at all? You'll even see the pressure plate move out a little? Will it get to a point where it won't turn anymore at all? I dont think I turned mine in enough? I stopped when I felt the screws first make contact and stopped turning easily. I could have kept turning them more but the pressure plate was moving out and it seemed this would cause excessive slippage.
Damn I'm so slackin...still have to do this mod.
