just replaced my battery....the bike won't keep it charged...any ideas, I put the voltage meter on the battery while it's running and there's only about 10 volts moving through...
How high are the RPM's when you take the reading. Most bikes do not charge under 3G's.
there is a problem w/ ur charging system...u should read about 14V across the batt. terminals. check all the connections, but since u r getting some voltage, u'll probably be replacing some hardware.
had the same problem for awhile and it turned out to be a connection that constantly rattled loose on the battery post. I thought it was much more serious at the time. It might be your charging system though.
