I have a project bike I've put together and I can't get it to stay running. Here is the rundown on what is happening and what I've troubleshot so far.
Turns over and starts up for about 5 seconds, if you give it gas it dies.
What I've looked at/replaced:
-fuel pump, verified it worked and the pressure was correct. Disassembled fuel pump and cleaned thoroughly.
-new injectors (old were clogged), verified new injectors are firing
-dealer mode to verify no codes
-fuel rail is not clogged
-fuel line is working/good condition
-checked the pin in the ECU that controls the fuel injectors, no visible issue
I didn't keep a list of everything I've done but I believe I have listed nearly everything. I've scoured the forums and tried anything that seemed relevant. Any suggestions as to what else I can try to get this to stay running is appreciated.
You didn't mention doing a flow test on the fuel pump. Did you? It's more important than the pressure test. Alternately, but harder to do, measure the pressure in the fuel line during the 5 seconds that the bike is running.
Yes, I did a flow test. I've gone over so many things it was hard to remember them all. I'll see if I can do as you suggested with the pressure when it runs for that split second. Thanks.
About this Discussion
3 Participants
dpapavas
Full Forum Listing
