I am thinking of trying my 1K steet bike's calipers on my 750 race bike. Anyone know if they are a direct bolt-on? What do you think of this as a performance enhancement?
direct bolt on with no issue.
perf enhancement? only difference between the two are the k3 1k uses a 4 pads setup an the k4 750 uses a 2 pad setup.
Fwiw, all the 04 use the same exact calipers
Thanks for the info. I'm thinking about trying it just because I've heard that the 4-pad set up might not transfer quite as much heat which some think is causing brake fade. Of course the pads cost quite a bit more, so if it doesn't make a noticeable difference I'll have to swap them back.
Thanks again.
