Has anyone ever heard of this swap?
I was looking at a 02 shock, and it looks like it mounts up the same way......
Lets say the fabrication and welding werent a question.....Comments.....
think this is an impossible swap?
[ 10-21-2002, 07:18 PM: Message edited by: z1bigtom ]
YAAFM Mod
Well Lets see... If possibe look at the two side by side.
Check overall length
Check both ends for width of the clevis/ball
If these are close you may be in the ballpark. The next fuel for thought is the valving and spring. You need to rememberthat the two bikes are almost 100lb different in weight so both of these will be off.
Bones
won't work, I tried it, but with a SRAD ( 99) shock but they are the same size...you would need to have a new link made...way too much time and money involved...save the bs and get a Fox...
-Karl
Karl........Dam!!!!!
My shock is wasted, and there are tons of 96-02 shocks all around....CHEAP!
Just like with this USD setup/////
I dont really want to piecemeal this switch.....
Cant seem to locate a complete setup!
If i do, its way over priced.....Well to me it is!
thanks for the info....
