Download a free manual for your bike and check there the exact voltage the TPS is supposed to have...You can also try to clean the sensor with some WD-40. Did it throw a FI fault on your dash when you rode the bike without the TPS?
not sure if I read it here.... or under a different thread... but I was having stauling issue after a fast rev... it would rev down and staul . and or coming to a light in gear sometimes and pull clutch in it would staul!!!
I have had the tps sensor out before put a little grease inside it and put it back on and used the dealer mode and got the line in the middle of the c00 display or what ever it says.... it made such a difference it was nuts!! bike started to wheelie .. I lowered the bike to stop that ... once I did this fix I know it was making way more power .. the rear tire wanted to break loose sometimes and loved to lift the front tire when on some hard pulls!!
anyways stauling was still not fixed ... this year tried the bike out a few times and the stauling almost felt worse
so I did what I read here and I know on another post.... about checking the tps sensor for it to spring back... man I coulnt even turn it either way very much without giving it some muscle... hhhmmm I think I found the culperate . so I did the 24-30 hours soaking in wd40..... wow it actually worked and worked mint , I took out the secondary tps to check it , it was springing back perfectly!! so I bolted it back in the spot it was from factory ( I even scored it with a knife to make sure)
so I put the main tps sensor back in today , did dealer mode adjusted it in the middle ... started wow doesn't staul and I can rev the shit out of it and it revs back quickly!! volia got that adjusted! so I used my manual I have and read about the secondary , u unplug it and used a voltmeter on ohm and unplug sensor from bike , use the yellow to + ON THE METER and use black to the negative on the meter . should read .5 k ohms.... it was at .9 so I adjusted it , and is supposed to show 3.9 when fully open/// was at 4.7 before
you just move the secondary servo controlled butterflies to move that secondary tps sensor!!!
wow it revs mint and I bet the computer never got such accurate readings as it is getting now ... didn't go for a ride yet but man the way its running is mint!!
take it for a haul tomorrow after work and will report back!!!
but 1000% the wd40 trick works!!!
