Hey guys,
I got an 01 750 off a guy. He said he put it up one day then couldn't get it to run. I checked wiring to fuel pump relay with test light. Everything seems good. Good prime signal, Good Ground, Postive seems very dim. I replaced fuel pump. Fuel pump pumps when put to 12v. I can hear and feel the fuel pump relay clicking. However the bike will not prime. I can remove the fuel line from tank and there is no fuel blowing out. I have FI light on but no codes pop up or rather I get 00. I'm loosing my damn mind and the weather is perfect. Please any ideas or direction I might have missed. Any links anything.
keep tracing the wiring back, fuses good? manual has wiring diagram, keep testing backwards from the pump lead plugs in under the tank, no power there right? test it back at the next junction, if there is power there then check the lead forward for continuity..
just a matter of tracing the fault.. takes time, you'll find it
