1 - 11 of 11 Posts
I took my stock 01 750 to The track for the first time last tuesday..The bike is stock with a slip on..I only got 2 runs and I bogged them both..First run was [email protected] with a 1.9 60 ft time, next pass I ran a [email protected] with a 2.0..I'm going back again this tuesday earlier so I can get more then 2 passes and hopefully get some 1.7's and run mid 10's..The 10.3's that the mags are claiming just seems a bit fast for this bike, but I was racing in 80 degree high humidity so we'll see next time..Anyone else on this forum race their 750 at the track??I haven't seen any numbers..
mine is
got a 02 750
d&d bolt on, k&n air filter, pc3 with arrow map
with stock gearing best was 10.83 @ 128 mph i was 219 lbs and add full leathers
temp was mid 70's, in texas, about 40ft elevation
with -1 in the front 10.73 @ 132 was about 205 with leather jacket added over that
temp was 40's, in texas
never set up the suspension for drag though, so could be faster.
Cool, It's kinda tough to determine your before and after result of the sproket though, being that the temps were 30 degrees apart..Is it typical to gain 4mph from a mild sprocket change??That would be a nice jump..Seems like your getting off the line pretty well, were you getting 1.7's or so??Whats considered an excellent 60ft time for a stock bike??
02 750 slip on pipe -1 front +1 tre mod 25mm lower on triple clamp remapped and dynoed 120.3 using front straps soft on comp hard on rebound.have done lots of runs best 10.307 time slip reads 10.307,135mph,RT .12,0-60 1.76,330-4.51,660-6.74,1000-8.66.shifting at 13000rpm launching 5000-7000rpm bike will go a little quicker as i have had a 1.68 0-60 but skipped a gear.i am 145 in leather the temp was 28 and the humidity was around 50%.
Nice times..I went back again for 4 more runs..I managed a [email protected] time it was 85 degrees F 84% humidity and I am about 180lbs dressed..I beat a kid on an 05 R1 3 times so I was pretty happy..I also ran a [email protected] and 2 10.9 passes..Next I'd like to strap the bike and change the sprockets and see what kind of gain I get with that..I also need a new air filter..Here is how my timeslip reads..
60ft 1.865
330 4.762
1/8 7.040
mph 107.36
990 8.963
1/4 [email protected] mph
Anyone else have stock timeslips to compare to??
i need my fat ass to be lighter, i am well over 220 in leathers, prob around 230, which is how we have to run when we go over 120 mph
[email protected] stock (except yosh full system)
i used to drag race bikes a long time ago..
i got an 02 750, lowerd, streched,geared, yoshi cams, full yoshi exhaulst remap. set up fpr the 1/8 we dont have a 1/4 mile around hear. goes 6.35's at 118 mph consistantly.
145! fuck your light niecey!!! i thought i was light at 80kgs kitted up
1 - 11 of 11 Posts
