I just recently bought a 2001 GSXR1000 with 9,000 miles on it. The bike is in great shape but I have had it not want to start twice on me. It just cranks and cranks but won't fire up. I had a friend swap out the tip over sensors and it started right up but then it did the same thing again to me today. Anyone have any clues?
Check the wiring on sidestand cut out switch, it can be a real bugger.....
There is a general flow chart to follow with these soughts of issues - getting fuel ? Getting spark?....get yerself a manual...
Si.
Can you hear the fuel pump prime when you turn the key on?
Mines doing the same thing all of a sudden, gauges read check, etc.
I popped the relay under the fuse box and reseated it.... bike fired up fine after that.
Had eveerything die on me at a light, bike stalled, would not crank, but lights and everything were on.
Noticed no fuel pump prime when I turned the key though. That's when I popped the relay and reseated it. Try that next time, mines only got 7000 miles on it but I guess they can go bad. If anyone has any other ideas I'd be glad to hear them.
