121 - 140 of 148 Posts
I know its a bit old but I'm trying to figure out what I've read and if I'm right. I have a k8 750. Found a set of 08 hayabusa wheels for cheap. Only difference I'm seeing are the rotor bolt holes are 5 instead of 6. Will 06 750 rotors fit the wheels and match up to my k8 calipers
I need to make some trigger wheels for an aftermarket traction control system. Does somebody know what is the PCD of an 01-08 rear brake disk?
I'm going to try these first and see how they would work. Both have 30T (pulses)
Wow what a post! Been searching like mad to try sort my issue and think Frankie has done me proud!
I have wheels and discs from my k1 750 and now own a k6/7 750. I'm aware the K1 discs are 320 so am I right I'll need a 5mm spacer for the caliper on my k6?
Do I need any spacers on the rear wheel?
Thanks again as this post has been brilliant! Made me realise I don't need new wheels!
Sent from my D6603 using Tapatalk
Hey, i have a k4 1000 and i have 2012 brembo front calipers for it....being they have 310mm rotors on them will 07/08 rotors work for me, or sv1000?
Does anyone know the weight differences between the k3/4 and the k5-8 wheels? the earlier ones definitely look chunkier, which isn't necessarily a bad thing if you consider pot holes on the street.
Anyone know if I can put a newer front wheel on a set of 2001 GSXR 1000 forks?
Doing a custom build with 01 1k forks and hoping an 05-08 front wheel will work with them as they seem easier to source and therefore are cheaper!
Any advice appreciated, thanks!
