81 - 100 of 151 Posts
contact Zoran. do a search and you'll find his email.
question here:dunno. will rotors off a 06' gsxr 750 fit a 08' gsxr 600. jst came back from a trackday and saw that a strap failed in my trailer causeing it to fall and rest on the rotor.
Will the GSXR 1000 K9/L10/L11 wheels fit a GSXR 1000 K8. Need some wheels for my rain tyre:)
I´ll buy the wheels with rotors. so no rotor swap
^See post #14. Note that the K9 front rotors are attached with 6 bolts instead of 5. Plans not to swap very commonly go astray and leave you wanting to swap but unable to.
will k7/k8 rear wheel fit k9 1000?
do i need to modify spacer and caliper bracket?
thanks!
I have a GSXR 1000 K6 front end. I only have tripple tree and forks with the axle bolt. And i am searching for a Front Rim to fit my K6 1000 Forks. What rims can i purchase and bolt on? i havent bought discs yet.
"All GSXR wheels after SRAD will fit any GSXR forks described above
The rotors change sizes (and fitment) however"
Nice chart. But what is "bore"?
i have the 2006 1000R forks, and i have got myself a 1000R 2009+/600,750 2008+ front rim.
I see that the rotors are the same diameter so then i can buy 2009 rotors(6bolts). If not it is getting in conflict with the "bore" whatever that is...
bore is most likely the center bore of the wheel, where the wheel bearing would sit.
No, because i have measured my wheel and a k7 1000r wheel. Same bearings. But when i think about it...maybe it is the "inner ring" of the rotor. 102mm..that i did not measure. I will measure that on monday on my rim and the k7
Addicted to Track
I am doing a SRAD 1000 swap with an 06 1000 motor. I am using 06 1000 wheels on a SRAD. The front I have figured out.... because I used 06 Forks and Triples. The rear is where I have a problem. Using the Swingarm, Caliper hanger and Wheel Spacers for the SRAD ... when I tighten the rear axle the rear wheel won't move freely.
If anyone has done this Swap before.....
Where do I shave material off ?
or
Where what parts should I substitute?
or
Does anyone have measurements for bearing spacing?
