07 GSXR 600 - Gas Light - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 2 (permalink) Old 07-04-2019, 02:10 PM Thread Starter
My gas light is always on solid or flashing even on a fresh top up. Sometimes it works properly for a split second, then it always goes back to going bonkers. What do I need to replace to get this fixed? Thanks yall.
playbooster is offline
post #2 of 2 (permalink) Old 07-05-2019, 05:18 AM
Married his Fleshlight... And Also touches people in a "special" way
Re: 07 GSXR 600 - Gas Light
Theres a float on a metal arm inisde your gas tank, which moves as the gas level lowers. Yours is either stuck or malfunctioning. You will need to drain and remove your gas tank, fuel pump and then inspect the assembly.
Sent from my SM-J250G using Tapatalk
bentoverhard69 is offline
