2006 750 is not idling high on cold start - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 2 (permalink) Old 02-11-2019, 04:26 PM Thread Starter
Hasn't been started in a week in this 30degree Fahrenheit weather. Started it up today and idled around 1400 for 10 seconds then went back to 1200 to normal idle.
JamesIsMe is offline
post #2 of 2 (permalink) Old 02-12-2019, 04:25 AM
Re: 2006 750 is not idling high on cold start
Sounds like high idle is kicking in, but, if that 10 sec duration is accurate, it should last a lot longer. The manual (see page 5-24) mentions
When the engine has warmed up, depending on the water temperature, ambient temperature and lapsed time, the fast idle is cancelled allowing the engine to resume idle speed.
but then proceeds to list fast-idle durations and speeds vs just ambient temperature in a table. At any rate at 30F, the duration should be more than a minute and your speed should be higher too. Assuming your water coolant readouts look normal, perhaps the ambient air temperature sensor isn't reading properly for some reason?
2006 gsxr 600 ticking cold start help dexint88 06-07 GSX-R600/750 16 01-12-2016 05:05 PM
Cold start idling issue grabbert 01-03 600 and 00-03 750 8 03-15-2015 02:58 PM
gsxr 750 k6 question on FI light and cold weather modru2004 06-07 GSX-R600/750 2 11-17-2008 10:04 AM
