06 gsxr 600 starting issue / misfire ? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 7 (permalink) Old 07-25-2018, 10:17 PM Thread Starter
My bike wouldn’t start I changed the starter motor and the bike still won’t start what should I check for that can be failing ? And before it stopped starting it was starting without need to hold clutch to start just mentioning if it matters .
Nicholas Georgio Johnson is offline
post #2 of 7 (permalink) Old 07-25-2018, 10:19 PM Thread Starter
And o forgot to mention about the misfiring issue , I can’t really tell if my bike is misfiring after I put new sparkplugs in , how to tell ?
post #3 of 7 (permalink) Old 07-26-2018, 04:02 AM
Re: 06 gsxr 600 starting issue / misfire ?
When you turn the key, shift to neutral and switch the engine stop switch to RUN, do you hear the fuel pump prime? Do you see CHEC on the dash, or the coolant temperature?
post #4 of 7 (permalink) Old 07-26-2018, 11:11 AM Thread Starter
Yes , I can see those things , I can push start it
post #5 of 7 (permalink) Old 07-26-2018, 11:47 AM
TheGeek's Avatar
Clutch switch is highly suspect. Or the start switch, or the starter relay....
TheGeek is offline
post #6 of 7 (permalink) Old 07-26-2018, 01:33 PM
See the diagram on 9-12 of the service manual. Things are probably OK through the engine stop switch if you can push start it. Should be easy to track down with a multimeter. Sometimes the start switch contacts get corrosion on them.
post #7 of 7 (permalink) Old 07-27-2018, 11:28 AM Thread Starter
Had to change starter relay , thanks !
