What is a TRE - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 33 (permalink) Old 02-10-2009, 05:02 PM
Superbike
V2rider's Avatar
Motorcycle: 2011 GSXR750 on the way
Re: What is a TRE
Originally Posted by TheGeek View Post
A TRE eliminates the timing retardation in the lower gears.
However, the retardation is only in effect below 50% throttle and in the lower RPMs.
Bottom line. The TRE will do nothing for you that you couldn't do before just by twisting the throttle. The only noticable change will be that it drasticly lessens the engine braking.
There is a definite improvement when rolling on the throttle. It feels ALOT more responsive for the reasons you explained. If you roll on the throttle in 2nd gear, up to half throttle feels like a dog compared to having a TRE. Just my opinion.
V2rider is offline
post #22 of 33 (permalink) Old 02-10-2009, 05:22 PM
J-Seekz's Avatar
Motorcycle: k6 600, k3 600
Re: What is a TRE
the x-tre by healtech retains the gear indicator as well.
just got one from ebay.
J-Seekz is offline
post #23 of 33 (permalink) Old 02-10-2009, 05:35 PM
Only Here to LOL & +1....
Buster Hymen's Avatar
Motorcycle: K7 750 Crackbike
Re: What is a TRE
how much?
Buster Hymen is offline
post #24 of 33 (permalink) Old 02-10-2009, 06:54 PM
J-Seekz's Avatar
Re: What is a TRE
about 165 CDN. not the cheapest, but i like that indicator.
J-Seekz is offline
post #25 of 33 (permalink) Old 02-10-2009, 07:26 PM
Motorcycle: K-5 GSX-R 1000
Re: What is a TRE
I purchased the X-TRE from HealTechElectronics. I have a GSX-R 1000 ,2005. It works as they claim. If someone is telling you it's not worth it? They just don't know. It maintains your stock gear position indicator. And the throttle response is very good. For a simple 129.00, it will be worth it. Yeah, you get to cut 1 wire. Make sure it's the correct one. No extra gear position indicator, needed. I think some dudes just aren't fellin' it. It's that riding thing again.
frank2 is offline
post #26 of 33 (permalink) Old 02-10-2009, 08:09 PM
Electronics Technician
GixxerBarry's Avatar
Location: Riding around So Cal, from the canyons to the track
Motorcycle: K7 GSXR 600
Re: What is a TRE
This was already clearly stated. For those of you who like to wheelie it is a great mod. If you are a track rider, then it depends on your riding style. 600's are geared for 3rd into the corners. So it helps throttle reponse regardless. And if you ride the front brake (trailbrake) deep into the turns then it is well worth it. Argument over, buy one and you be the judge.
GixxerBarry is offline
post #27 of 33 (permalink) Old 02-10-2009, 08:25 PM
Motorcycle: 750 k8
Re: What is a TRE
Originally Posted by GixxerBarry View Post
HealTech makes a great plug and play TRE. It's called the GI Pro A TRE it also has a luminating screen that tells you what gear you're in. Your speedo will tell you what map you are in. It has 4 settings, 4, 5, 6 and 7. All of them have a dramatic effect on your throttle response at lower speeds. I think I ordered mine from Calmotorsports or something. Just google healtech GiPro A TRE. It is well worth it IMO. For any CC sportbike.
+1000 bro !!! i also have this mod. and agree wit u, very worthwhile for the $$
krazykt is offline
post #28 of 33 (permalink) Old 08-23-2009, 03:02 AM
gold333's Avatar
Re: What is a TRE
If I understand it correctly you can just circumnavigate the TRE limitation by twisting more throttle if you want?
It's effect is like the linearity of the throttle setting in racing games? If that makes sense? I.e. 0-25% twist is 0-15% throttle opening, 50% twist is 35% opening, 80% twist is 70% opening, 90% twist is 85% opening and 100% twist is 100% opening? I.e. it makes throttle control easy for you?
If I understood it correctly I'll keep it. I have trouble being smooth on the throttle as it is on the 750.
'99 SRAD 750 5k miles
'99 SRAD 750 11k miles
'03 Aprilia RS250
gold333 is offline
post #29 of 33 (permalink) Old 04-28-2010, 09:47 PM
spydigtconv149's Avatar
Motorcycle: 07' 750
Re: What is a TRE
will this help for picking up e.t. in drag racing?
spydigtconv149 is offline
post #30 of 33 (permalink) Old 04-28-2010, 10:23 PM
Re: What is a TRE
No, it won't help you with drag racing at all. You have no time at low rpm and a small throttle opening when you're drag racing. I'll tell you one place it sure does help though.
Riding on a wet track. It helps a whole bunch to have smooth throttle response at smaller throttle openings when you are riding track in the rain. There is plenty of time spent just feathering the throttle, and any jerkiness on your part, or the bike's part, will take you down.
I just spent a weekend doing just that. Some semi-dry sessions, but more wet ones. I'm glad I had this mod. You can't just be smoother on the throttle to make up for a jerky throttle response in those conditions. People were dropping like flies as it was, regardless of what brand or model of bike they were on.
Zippysport is offline
post #31 of 33 (permalink) Old 04-29-2010, 12:42 PM
RidgeRacer's Avatar
Motorcycle: '82 GPz550
Re: What is a TRE
I uploaded these for another thread but I might as well post them here...
(These are for K6/K7 US GSXR-750 (32920-02h10)
Ignition Map (Group 1/2) used in 1st - 4th gear.
Ignition Map (Group 3) used in 5th and 6th gear (all gears with a TRE).
Compare Map ( Group 3 minus Group 1)
RidgeRacer is offline
post #32 of 33 (permalink) Old 04-29-2010, 01:10 PM
T.R.E's Avatar
Motorcycle: GSX-R 1000 K7
Re: What is a TRE
Again I'd like to thank you for sharing,so there is not really much gain to use a TRE on the 750...
T.R.E is offline
post #33 of 33 (permalink) Old 04-29-2010, 01:25 PM
buddy179's Avatar
Motorcycle: 06 750
Re: What is a TRE
so the spot in the comparison group is the spot that the timing is retarded by the 1-4 gear ignition maps. And when we can flash the ECU, those spots will be adjustable with a computer anyway, right??
buddy179 is offline
