Fork ID help - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 11 (permalink) Old 11-21-2018, 02:27 AM Thread Starter
Fork ID help
Hi all, hoping for some help identifying a set of forks I have. I am led to believe they are from a GSXR1000 but year is unknown. Forks have ohlins TTX inserts FGK 2071. It has Red rebound adjusters on the bottom? All helps appreciated. Cheers
Dylan Gulliver is offline
post #2 of 11 (permalink) Old 11-21-2018, 08:57 AM
Re: Fork ID help
Hmmm....my best guess is those are from a 2009-2011 GSXR-1000 given the TiNi coating on the lower fork tubes. On the '12 1000 (and also the 2011-2018 600/750) they all have chromed lower fork tubes.
The 09-11 1000 didn't come with those Brembo calipers OEM either, it came with the Tokico monoblocks, but its easy enough to swap the calipers out as they are the same spacing....I have the same calipers on my K5 1000. BTW, I believe those are Ohlins 30mm NIX cartridges so the rebound would be at the top of 1 of the forks (should be the right leg) and comp at the top of the other, the red plug at the bottom is just a dummy/blank cover...but on the stock OEM internals that would be the preload adjuster, not rebound.
"I never drive faster than I can see...besides that it's all in the reflexes."
-Jack Burton
CCS AM #478
SPL170db is offline
post #3 of 11 (permalink) Old 11-21-2018, 09:28 AM
Re: Fork ID help
Just for some additional info, I don't see a listing for an FGK 2071 fork kit. But the FGK 207 is the 30mm road and track kit for the 2009-2011 GSXR-1000
https://www.ohlins.com/app/uploads/w.../MI_FGK207.pdf
And they're not the TTX carts (which are the gas-charged) as you mentioned above because it's the wrong part number, those would be FGR-157's
https://www.ohlins.eu/en/products/mo...fgr-157--4152/
SPL170db is offline
post #4 of 11 (permalink) Old 11-21-2018, 12:27 PM
Re: Fork ID help
+1 on what SPL said. The NIX cartridges say PRELOAD on both sides plus REB on one side and COMP on the other. A shadow prevents me from reading yours. You could also measure the tube OD at both triple clamp mounts as an indication of what you have. The NIX cartridges get installed into forks that they're not officially for. I have FGK 2103 (I think officially for Ducati) in my K6.
post #5 of 11 (permalink) Old 11-21-2018, 02:31 PM
-JK750-'s Avatar
Motorcycle: K5 1000 & K1 750
Re: Fork ID help
It could be the picture but coating looks darker than my bike's K9 forks. Maybe the forks are K8 or earlier.
Do what BillV said - measure the diameters.
-JK750- is offline
post #6 of 11 (permalink) Old 11-22-2018, 02:26 AM Thread Starter
SPL - sorry was ment to say NIX not TTX cartridges. The calipers are from a 2012 from what I was told.
Good to know the red plug is just a dummy cover as all pics I could find were of blue or silver ones.
Have not had a Big play with these forks yet as bought them for the RGV from a guy who had them revalved and resprung
BillV - OD of upper is 50mm and lower is 55mm
Cheers for all the info guys 👍
post #7 of 11 (permalink) Old 11-22-2018, 02:59 AM
-JK750-'s Avatar
Re: Fork ID help
50/55mm = K9-L1 forks.
-JK750- is offline
post #8 of 11 (permalink) Old 11-22-2018, 02:57 PM
Re: Fork ID help
That lower adjuster is the spring pre-load on K9-L1 and, per the service manual and online pics, is blue with eight holes. Possibly yours were replaced because of some issue with the NIX cartridges. Or maybe other applications use red adjusters. Compare yours with this, particularly the legs for mounting the fender and caliper:
P.S. I just noticed this thread where he put ZX10R BPF forks onto a Triumph. They have the red adjusters. So that may be where yours came from.
post #9 of 11 (permalink) Old 02-08-2019, 06:29 PM
57x
Motorcycle: 05 GSXR 1000, 01 GSXR 1000, 91 GSXR 400 SP2, lots of Kawi's, Yammer's
Re: Fork ID help
P.S. I just noticed xxx thread where he put ZX10R BPF forks onto a Triumph. They have the red adjusters. So that may be where yours came from.
Ignore the adjuster on the bottom. It is now decoration, just a plug. 30mm NIX and the 25mm TTX Gas Charged both only adjust from the top. The top nut is for preload. One fork will say 'REB' for rebound and the other fork will say 'COMP' for compression. You only adjust one side for rebound and the other for compression using an allen wrench. Your third pic shows that is the rebound fork.
Ohlins part numbers on forks are all three digits after the model markings. The fourth digit is a revision marking, and has no impact on the parts inside.
FGK207 is the model and the 1 is the revision. You will see this on shocks, FGRT forks etc. A FGRT fork would be SU1112 (SU for Suzuki - 111 for model - 2 for revision.
57x is offline
post #10 of 11 (permalink) Old 02-08-2019, 06:31 PM
57x
Re: Fork ID help
ww.ohlins.com/product-item/61564/
ww.ohlins.com/app/uploads/world/documents/2015/05/MI_FGK207.pdf
57x is offline
post #11 of 11 (permalink) Old 02-08-2019, 06:32 PM
57x
Re: Fork ID help
I am too much a noob to post links. I cannot seem to get around the "big brother" reviews of my posts, so figure out what is missing to see details from Ohlins on your cartridges.
57x is offline
The Best Fork Seal Write Up Ever!!! Nitrod86gt Mods & How To's 124 12-21-2016 09:39 PM
Suspension 101 Gixxervan1000 Chassis, Suspension & Tire Setup 45 08-05-2016 03:16 PM
Fork Service - How To ECC3 Tech Tips & Tricks 17 04-03-2010 05:30 PM
Do I need a fork seal driver to replace my fork seals? cue8chalk 04-05 GSX-R600/750 14 06-22-2009 02:29 PM
changed my fork seals today nike General Bike Talk 0 02-04-2007 05:40 PM
