2005 gsxr 600 trouble running - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 4 (permalink) Old 02-22-2015, 04:34 PM Thread Starter
I have a 2005 gsxr 600 that won't stay running.
bike was running fine. Changed the oil and fork seals took it around the block and started running like crap. Pulled the tank and noticed fuel filter had desinegrated. Cleaned the tank installed new pump, cleaned injectors and new spark plugs still nothing. If I spray carb cleaner it starts and revs then dies.
Any help please!
ktmracing1993 is offline
post #2 of 4 (permalink) Old 02-25-2015, 11:13 AM
Motorcycle: GSXR 1986,03,10
Did you kink the high-pressure fuel line when you lifted the fuel tank ?
JJ Rossi is offline
post #3 of 4 (permalink) Old 02-25-2015, 07:32 PM
Re: 2005 gsxr 600 trouble running
Yep, sounds like fuel to me too. Is the fuel pump priming when you turn on the ignition?
You bought a brand new OEM pump?
If it is a used pump off another bike, it may still be plugged. There is an internal filter inside the pump that clogs up. There is a bypass mod for this on the forum.
If it is a cheap eBay pump, who knows...
Do a flow test. Check the manual for the specs.
Sabba is offline
post #4 of 4 (permalink) Old 03-13-2017, 09:27 AM
Fuel pressure should be 40psi or better
PodiumMoto is offline
