1000R and Lithium Battery Question - Suzuki GSX-R Motorcycle Forums Gixxer.com
 3Likes
post #1 of 24 (permalink) Old 12-10-2018, 12:28 PM Thread Starter
Hi, my name is Michael,
I'm new to the forum, and new to the bike, I got a 2018 1000R and decided to swap the battery (which is lead, despite the bike being announced with Lithium) for a Lithium battery (like I did on my other bikes) as a cheap way to save a few pounds.. I got myself an Antigravity battery, the YTZ-10S equivalent and mounted it with no problems.
On my first ride, the bike seemed to work fine, but after about 10mins the ABS light started flickering, bike stuttered, and then the speedo displayed zero, and both the ABS and Traction Control lights came on. Bike was running fine, but no ABS and TC.
I checked the sensor, and couldn't find anything by visual inspection. Before taking the bike apart to measure the sensor at the connector (under the airbox - sigh!), I swapped in the original battery and went for a test ride again. Everything was fine! None of my other bikes had a similar problem.
My question is, did anyone swap their battery for a Lithium and it worked fine? This would be on a 1000R with ABS still on the bike.
Thanks
kolby is offline
post #2 of 24 (permalink) Old 12-10-2018, 01:29 PM
Hi look forward to the replies you get as I’m looking to do the same in the future. 👍
Mallewis1963 is offline
post #3 of 24 (permalink) Old 12-10-2018, 01:57 PM
cdcom's Avatar
Motorcycle: 2017 GSXR 1000R, 2014 Aprilia Tuono
Re: 1000R and Lithium Battery Question
Those types of gremlins can happen when you have a loose battery cable. Maybe you you installed it slightly loose? or maybe the battery terminals are bad internally?
cdcom is offline
post #4 of 24 (permalink) Old 12-10-2018, 02:04 PM Thread Starter
It was definitely not a loose battery cable, I used serrated washers on the terminals, they were tight. Internally loose cables? Possible, hard to check without cracking the battery open.
kolby is offline
post #5 of 24 (permalink) Old 12-10-2018, 02:55 PM
Karns Performance's Avatar
Motorcycle: 05 1k- sold / 2012 1k
the lithium batteries can fail internally quicker than a lead acid one because there is wires inside that can come loose.
i switched to a ballistc with no issues.
jason
oldgixxer likes this.
Karns Performance is offline
post #6 of 24 (permalink) Old 12-10-2018, 04:22 PM Thread Starter
Hmm interesting, battery was brand new, and issue started 10 mins into a ride over a less than perfect (bumpy) road. Now I feel like taking the battery apart and find out
kolby is offline
post #7 of 24 (permalink) Old 12-10-2018, 05:53 PM
send it back if you take it apart they wont do any warranty just talk to them
jason
post #8 of 24 (permalink) Old 12-11-2018, 12:20 PM
jason
I am also using Ballistic with no issues.
gcally is offline
post #9 of 24 (permalink) Old 12-11-2018, 01:26 PM Thread Starter
Thanks for all your responses.
I just checked Ballistic's website, and it seems like they're shutting down operations.
I'm currently testing another theory, I retraced all my steps in mounting the battery in the first place, and found that I used a wrong bolt to mount one of the cables to the battery post.
The bolt was from the original battery and was tight, but bottomed out, so the cable could have been loose.
Maybe cdcom was right all along
I rode into work this morning, and so far no issues, but more testing is needed.
I'll update the thread with my findings.
kolby is offline
post #10 of 24 (permalink) Old 12-11-2018, 03:02 PM
I installed a Earth-X lithium battery in my '17 1000R during its first service and haven't had any problems at all since. I like the Earth-X lithium battery because it has a built in cell balancer.
chillwill543 is offline
post #11 of 24 (permalink) Old 12-11-2018, 04:07 PM Thread Starter
That's one of the reasons I bought the Antigravity, it has a built-in BMS protection against over-/under-charging, and cell balancing.
I did a one hour ride during lunch time, and fingers crossed, everything worked fine.
For now, I'm going with user error, connecting one cable with the wrong bolt to the battery pole.
Thanks everyone for your responses.
Back to waiting for Carbonin to ship some shiny parts
kolby is offline
post #12 of 24 (permalink) Old 05-23-2019, 11:04 AM
You've had a few months since post. Are you still problem free because I am having the same issue now. Thanks in advance.
Krkjones15 is offline
post #13 of 24 (permalink) Old 05-23-2019, 05:13 PM
Yorick_UK's Avatar
Motorcycle: 2019 GSXR1000
Can I ask how much weight you saved ? And how much it cost you ?
Yorick_UK is offline
post #14 of 24 (permalink) Old 05-23-2019, 06:30 PM
Hand-Eye Coordinator
MacBayne's Avatar
Probably saved a couple pounds but the cost is relative to where one lives.
MacBayne is online now
post #15 of 24 (permalink) Old 05-24-2019, 04:43 PM
Yorick_UK's Avatar
Bike and rider probably weight 600 pounds, so an expensive saving of 2 pounds seems a bit strange.
post #16 of 24 (permalink) Old 05-27-2019, 06:57 PM
NYYYYYAHHHHHHHHHHHHH!
XCSEDAN's Avatar
Motorcycle: GSXR-600 K3
For a yuasa lead acid battery i was quoted $200 for factory replacement (best deal i could find on the YTZ10S, was quoted up to $349)
$300 for a high end lithium with cell balancing and surge/short protection
weight saving is about 2kg with this particular battery (R has small battery from factory), for a normal size bike battery its 3-4kg, its handy as a bi-product, but unless its a race bike its kinda pointless, the main reason for wanting one is the fact they don't discharge when sitting idle, also they tend to hold a higher cranking capacity compared to AH than lead acid.
cons - dangerous if shorted/overcharged/overdischarged, cannot use normal charger, must use a lithium type charger.
K3 600 Gixxer: Nicknamed; DROP SLUT - RIP 15/1/16 killed by a suicidle kangaroo - nek minnit track bike
07 CBR1000RR - Dead thanks Mr Cager
L7 GSX-R 1000R - Black - Stock
XC Falcon Sedan (351, toploader, 9"), 97 MX5 - Daily
saying of the day "she wants an Alabama Hot Pocket"
XCSEDAN is offline
post #17 of 24 (permalink) Old 05-27-2019, 09:09 PM
Gottspeed's Avatar
Motorcycle: K41K
LOL you can get a ghetto brand LA battery for like 80 bucks here in Canada. Left it in all winter and it still works.
proze likes this.
Gottspeed is offline
post #18 of 24 (permalink) Old 05-28-2019, 09:12 AM
Motorcycle: K5 GSXR 1000 , K2 GSXR 1000
I was going to buy a Lithium for my K5 1000 but two of the battery shops i spoke with advised me to stay away from Lithiums for now as the technology isn't quite there yet for some older bikes. I also heard 2 stories of them overheating while riding on a couple of bikes. Has anyone used a Lithium on any older models with success?
ddnova is offline
post #19 of 24 (permalink) Old 05-28-2019, 05:39 PM
I've used lithium batteries on both my K6 and my 2008 B king for years with complete success so far. Both were Ballistic brand.
I'm using a Shorai lithium in my KTM 1290 with good results also.
Imbroglio1945 is offline
post #20 of 24 (permalink) Old 05-29-2019, 01:36 AM
XCSEDAN's Avatar
you can get cheap ones here too for around the $100-120 mark but not in the factory R size, or i could build my own if i really wanted to.
I've worked with lithium batteries since 2003, i want one with an inbuilt cell balancer and short protection, they produce a chemical fire thats near on impossible to put out if shit goes sideways.
cheap ones are just a battery, no circuit protection, no inbuilt balancing and no voltage cutoff = accident waiting to happen
that's complete bullshit, maybe issues with cheap batteries perhaps, but lithium cells have been commonplace since early 00s in other systems, the techs good to go, I've had one in my k3 since 2013/14.
as always look for a reputable brand though, but so long as your voltage doesn't spike, an older bike should be fine
XCSEDAN is offline
