shenninagans at the strip!!! - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 4 (permalink) Old 08-03-2015, 12:54 AM Thread Starter
took my k8 750 to the track yesterday
ran a 10.5 at 126 terrible 60ft time and my 1/8 mile mph was 105 any other 750s seeing that little mph pick up on the big end?
stretched 12" droped 2 in the back none in the front leo vince exhaust bmc filter velocity stacks, im not sure on the gearing i need to pull the cover off and check it
dragngsxr is offline
post #2 of 4 (permalink) Old 08-15-2015, 11:18 PM
Motorcycle: 2007 GSXR 1000
Re: shenninagans at the strip!!!
Maybe I'm not understanding but why are you stretched so far with so little power? You're sucking the life out of that thing. I'm 8 and bit over on a 1000 with a small shot of spray and that's pulenty.
Is the ECM flashed, are you using a PCV or Bazazz or what?
Ken7-1000 is offline
post #3 of 4 (permalink) Old 08-16-2015, 06:12 AM
Guest
Hard to answer such a general question,but u need to find out what gear you are going through the traps in,and at what rpm.
Example,my Busa goes through the traps in 4th gear,exactly as the shift light comes on. That is exactly how you should be geared,to cross the line at the top of whatever gear with the rpm a hair under the rev limiter.
Also,if your 60' and 330' are off,you're mph is gonna be off as well.
Document so more specific info and then get back to us
post #4 of 4 (permalink) Old 08-21-2015, 03:45 PM
d3coy's Avatar
Motorcycle: 76" Black/Orange GSX-R 1000 K7
a 66" wheelbase (10" stretch) on a 1000 is bout the border-line for effective wheelbase on a stock motor, so 12" on a 750 seems like overkill. probably doing it's part to contribute to the lackluster 60fts. alone or in conjunction with too little gearing.
d3coy is offline
