2007 GSXR750 Cracked sprocket cover - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 11 (permalink) Old 04-02-2016, 01:19 AM Thread Starter
I replaced the the sprocket cover on my track bike which is a 07 Gsxr750 and not sure why it cracked. Well I noticed at the track the new cover also started to crack. I did notice that the old cover it had a grooved hole develop in the inside and I think came from the metal rod that come out on the left side of the engine. I have not taken thenew one off yet to inspect it.Not sure what is causing it..Need help...Thanks Ray
Ray51 is offline
post #2 of 11 (permalink) Old 04-02-2016, 01:39 AM
nannynooch's Avatar
Motorcycle: k7 blue and black Gsxr 750, and HD Iron 883
Re: 2007 GSXR750 Cracked sprocket cover
Welcome to the Forum, I have no idea about your question.
nannynooch is offline
post #3 of 11 (permalink) Old 04-02-2016, 03:24 AM
Motorcycle: 2015 GSXR 750
Aftermarket sprocket and still running the stock washer/spacer under the nut ?
Ben750au is offline
post #4 of 11 (permalink) Old 04-02-2016, 04:36 AM
Guest
Are you referring to the clutch push rod?? #27 on the parts fiche below
Motorsports Honda Yamaha Suzuki Kawasaki Motorcycle Dealer ATV Greenville NC Used Sport Bikes Eastern North Carolina Hustler mower, Honda Power equi
post #5 of 11 (permalink) Old 04-02-2016, 11:54 AM Thread Starter
Yes #27. I found this pic of what exactly is going on....
Ray51 is offline
post #6 of 11 (permalink) Old 04-02-2016, 11:56 AM Thread Starter
I don't remember. Here's a pic....
Ray51 is offline
post #7 of 11 (permalink) Old 04-02-2016, 01:51 PM Thread Starter
Up close.....
Ray51 is offline
post #8 of 11 (permalink) Old 04-02-2016, 01:56 PM Thread Starter
Up close....
Ray51 is offline
post #9 of 11 (permalink) Old 04-02-2016, 07:56 PM
Guest
That looks like the it was caused by the allen bolt that holds the rotor for the speedometer sensor. have you changed sprockets? It should be fairly easy to see whats making contact when you go to install the cover....
post #10 of 11 (permalink) Old 04-02-2016, 10:08 PM Thread Starter
This is the cause...bolt of sprocket backed out..everybody thanks for your help.
Ray51 is offline
post #11 of 11 (permalink) Old 04-03-2016, 04:58 AM
Guest
Lol,once you posted pics of the inside of the cracked cover I knew right away it was from the allen head bolt that holds the rotor for the speedo sensor.
