Front Disc offset difference between Slabside and Slingshot models - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 12-08-2014, 12:16 PM Thread Starter
Motorcycle: Currently re-building 1985 Harris F1 GSX-R750
Please can anyone advise the front disc offset difference between the earlier Slabside and Slingshot models. I'm assuming they're both 310 mm, 5 hole fixing?
I have a Dymag front wheel with a hub width of 99 mm (Slingshot is 93 mm) so have problems fitting the standard calipers unless I make brackets. I was hoping that the earlier discs may sort my problem!
Last edited by AndyC; 12-08-2014 at 12:45 PM. Reason: Apologies, posted in wrong area and can't figure how to delete!
AndyC is offline
post #2 of 3 (permalink) Old 12-08-2014, 12:46 PM
Motorcycle: 2011 gsxr750
Re: Front Disc offset difference between Slabside and Slingshot models
Wrong section . This is for WEB SITE questions and comments.
Motionelco is offline
post #3 of 3 (permalink) Old 12-19-2014, 02:51 PM
Factor
Motorcycle: GSXR1K5, GSXR1100G
86-88 1100 & 85-87 750 are 21.5mm. 89-98's 1100 & 88-95 750 are 22mm so essentially the same offset. But bolt circle (81 vs 86) and hub diameters (61 vs 64) are different. And 85-87 750 are 300mm xc LTD is 310 same as 1100's. All are 5 bolt. Good luck.
remusr is offline
