GSXR 750 Oil coming out of PCV - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 05-29-2012, 01:20 PM Thread Starter
Motorcycle: 1998 GSXR 750
I clean the air box put her all back together and let idle for 15 minutes and there is oil in the air box. so Oil is coming up out of the Pcv... Why??? is there another vent line that could be plugged on the Crank case or should i get a new check valve.
the bike has around 16500km on it the motor was swapped a to winters ago.
it also kicks between 4200rpm to 5000rpm. it just hates revving at that rate could this be related?
Thanks Friends
HarryNadz is offline
post #2 of 3 (permalink) Old 05-29-2012, 01:23 PM
Douche Nozzle
Wogger's Avatar
Motorcycle: 09 GSX-R 600, 09 DR-Z434SM, 82 CB750F, 05 CRF50F
Re: GSXR 750 Oil coming out of PCV
Wrong subforum
Wogger is offline
post #3 of 3 (permalink) Old 05-29-2012, 01:32 PM
Motorcycle: K7 GSXR 750
how much oil. A little oil is common and not a problem. if its alot you might have overfilled the crank case or bad piston rings
pocar is offline
