wont start 750 2000 gsxr - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 12 (permalink) Old 01-02-2012, 06:09 PM Thread Starter
ok i try everything and cant get it to work need help ?
2000 750 gsxr wont star turns over but wont start new batt / new ecm/
fuel presure tested/ changed plugs /rolling the bike to start / by pass the starter/coils tested
please help
teddyb is offline
post #2 of 12 (permalink) Old 01-02-2012, 06:13 PM
600gixgp's Avatar
Motorcycle: 600 k9
Re: wont start 750 2000 gsxr
do you have spark ,fuel and compression if so check timing
600gixgp is offline
post #3 of 12 (permalink) Old 01-02-2012, 06:28 PM Thread Starter
after about 20-30 times trying to start the bike will start and sometimes will run for 3-6 hrs
i can turn off and turn it back on and after 8hrs plus wont star again so i know its not timing problems
and two or 3 days later same problem if some how i get it start it runs perfect like nothing is wrong
but ill never know when will star and when wont any ideas
teddyb is offline
post #4 of 12 (permalink) Old 01-02-2012, 06:31 PM
600gixgp's Avatar
Motorcycle: 600 k9
Check your fuel pump and fuel filter, as well as check your bikes ground.
600gixgp is offline
post #5 of 12 (permalink) Old 01-02-2012, 06:37 PM Thread Starter
ground ?????? the battery ground??? and i do get fuel all the way to the fi
teddyb is offline
post #6 of 12 (permalink) Old 01-02-2012, 06:41 PM
2007gsxr600's Avatar
Motorcycle: L1 750
That sounds like a bad wire connection somewhere....
2007gsxr600 is offline
post #7 of 12 (permalink) Old 01-02-2012, 06:41 PM
Motorcycle: L1 750
Try checking the emergency kill switch on the right handle bar...
post #8 of 12 (permalink) Old 01-02-2012, 06:47 PM Thread Starter
okay i think i did by turning the switch off and trying to star and it wont start at
or any other way to tested
teddyb is offline
post #9 of 12 (permalink) Old 01-02-2012, 06:48 PM
600gixgp's Avatar
Motorcycle: 600 k9
Yeah the battery ground and all the other gounds in you connectors
600gixgp is offline
post #10 of 12 (permalink) Old 01-02-2012, 07:00 PM Thread Starter
okay ill try that too thank you
teddyb is offline
post #11 of 12 (permalink) Old 01-02-2012, 07:07 PM Thread Starter
??????????????anybody has any more ideas ??????????????
teddyb is offline
post #12 of 12 (permalink) Old 01-02-2012, 07:46 PM
ccmhunt's Avatar
Post your question in the correct sub forum, here is the description of this one: Ask questions about USING THE FORUM and make suggestions for making it better. BIKE-related questions do NOT belong in here. Please read the forum descriptions and post your questions in the right one.
ccmhunt is offline
