Is my 98 GSXR 750 fuel injected? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 18 (permalink) Old 10-17-2011, 10:06 AM Thread Starter
I purchased a 98 GSXR 600 with a 750 engine swap. The seller told me that the motor came from a fuel injected 98 GSXR 750. I brought the bike to my local suzuki dealership for its 20,000 mile service and in conversation the service manager had mentioned that the bike was not fuel injected. Is there a simple way that I am able to tell that the engine is fuel injected or not? Possible an engine stamp or serial number on the engine somewhere. Thanks for any help.
coppergsxr is offline
post #2 of 18 (permalink) Old 10-17-2011, 10:21 AM
600k2's Avatar
Motorcycle: 600k2
Re: Is my 98 GSXR 750 fuel injected?
lift gas tank and look.
600k2 is offline
post #3 of 18 (permalink) Old 10-17-2011, 10:59 AM
Hates the French..especially Le Skid
Motorcycle: Aprilia RSV Mille
cainyboy is offline
post #4 of 18 (permalink) Old 10-17-2011, 08:46 PM Thread Starter
I did and I see fuel injectors, but when you have a dealership telling you it is not fuel injected you question it. I asked for help not a smart ass remark.
post #5 of 18 (permalink) Old 10-17-2011, 09:52 PM
Motorcycle: 09 gsxr 600
does it have a choke? if it has a choke its carb.
erxloes is offline
post #6 of 18 (permalink) Old 10-18-2011, 01:05 AM
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Errrr...No!
They BOTH have a choke or fast idle lever that look identical so that won't really help.
THE SRADIATOR is offline
post #7 of 18 (permalink) Old 10-18-2011, 01:28 AM
Just because it "came from" an F.I. bike doesn't mean it is being used in an F.I system!
This motor can be converted back-forth fairly easily and what may appear to you as injectors may actually be the carb bodies or vice-versa.
Was that helpful or was that too smart-ass of an answer?
post #8 of 18 (permalink) Old 10-18-2011, 07:55 AM
ccmhunt's Avatar
JESUS......does anyone read the intended purpose of this particular sub forum?
Ask questions about USING THE FORUM and make suggestions for making it better. BIKE-related questions do NOT belong in here. Please read the forum descriptions and post your questions in the right one.
Post in the SRAD SUB FORUM OR GO HOME!
ccmhunt is offline
post #9 of 18 (permalink) Old 10-18-2011, 09:11 AM
Someone has not had their happy pill today!
post #10 of 18 (permalink) Old 10-18-2011, 10:20 AM
ccmhunt's Avatar
Want me to get one for you and Joe?
ccmhunt is offline
post #11 of 18 (permalink) Old 10-18-2011, 10:26 AM
I could give 1/2 my supply away to both of you and still have more than enough for me!
post #12 of 18 (permalink) Old 10-18-2011, 11:32 AM
Jesus Christ, You checked it and found injectors and you are still wondering if the bike is fuel injected retard
cainyboy is offline
post #13 of 18 (permalink) Old 10-18-2011, 11:45 AM
From under the air box, an untrained eye could mistake one for the other!
post #14 of 18 (permalink) Old 10-18-2011, 01:56 PM
Originally Posted by THE SRADIATOR View Post
Errrr...No!
realy, iv never see a F.I. bike with a choke lever on the handelbars or anywhere else.
aslo why would a F.I. system need a choke. its all computer controled?
erxloes is offline
post #15 of 18 (permalink) Old 10-18-2011, 01:59 PM
600k2's Avatar
Motorcycle: 600k2
nope, not at all. mine is the most basic FI can get. the choke opens the throttle a little bit and holds it. there is a 3rd cable for the choke on the throttle body and when pulled it rotates a lobe that pushes the throttle open a bit.
600k2 is offline
post #16 of 18 (permalink) Old 10-18-2011, 02:56 PM
ccmhunt's Avatar
Then you have never seen a fast start lever on a FI 97-99 SRAD 750 that looked to be a choke lever in the exact same place as the choke lever as the previous two years carbed bikes that looked identical.
ccmhunt is offline
post #17 of 18 (permalink) Old 10-18-2011, 04:43 PM
Motorcycle: 1999 750
removed negative previous comment.
Last edited by Sleeper_750; 10-18-2011 at 05:13 PM. Reason: removed negative previous comment.
Sleeper_750 is offline
post #18 of 18 (permalink) Old 10-18-2011, 08:07 PM
ok well i guess i have learned something today.
erxloes is offline
