Front End Lock, what to do? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 9 (permalink) Old 04-17-2011, 03:57 PM Thread Starter
drewww3636's Avatar
Motorcycle: 2004 GSXR600
So heres the story..
Riding home, its windy, really windy. Look up..see a 50 km/h zone sign, roll off the throttle a bit. Notice the bike is slowing down in a HURRY. Shit shit. Reach to feel the front brake lever, rock hard and all the way out, no dead zone. Brakes were locked up. Stopping in the middle of a 80 km/h road seemed like a bad idea. Look behind me, theres a Kia barrelling towards me, so I figure I need to get off, but it was a country road, so mushy shoulder. I down shift till I'm in second and touch rear brake to turn on brake lights. Thenn very very cautiously pull off onto this shoulder of death. As I stop bike tips over, sigh. NBD, no damage.
I did a search on the front end locking up, I think its the MC return clogged.
My question is..was there a better way for me to have handled the situation?
Thanks
drewww3636 is offline
post #2 of 9 (permalink) Old 04-18-2011, 10:34 AM
ezzywave's Avatar
Motorcycle: '07 GSXR750(street), '01 GasGas 280TXT(trials), '03 KTM SX200, '04GSXR750(track)
Re: Front End Lock, what to do?
Wow. That scares me just reading it. I don't know what else you could of done in that situation.
Did you by any chance recently put new brake pads on the front? When you replace worn out pads you have to push the brake pistons back into the caliper so they will fit over the disk. Sometimes this will push enough brake fluid back into the resevoir that it will fill it up completely. Then when the fluid gets warm it expands and the only place it can go is to the brake pistons.
I would check the fluid level before anything else. Let us know what you find out is wrong with it.
"The mind, once expanded to the dimensions of larger ideas, never returns to its original size..." ~ Oliver Wendell Homes
ezzywave is offline
post #3 of 9 (permalink) Old 04-18-2011, 10:45 AM Thread Starter
drewww3636's Avatar
No, I just changed the levers, bought off ebay (hangs head in shame). I'm going to check the fluid level, and make sure the MC piston can return fully with the new levers.
post #4 of 9 (permalink) Old 04-18-2011, 10:57 AM
05Duramax07's Avatar
Motorcycle: '05 GSX-R 600
I keep reading these threads about people changing levers and then the front end locking up, Whats the issue? Makes me not want to change levers.
05Duramax07 is offline
post #5 of 9 (permalink) Old 04-18-2011, 11:11 AM
Pro-Lux-Racing's Avatar
Motorcycle: A Gixxah!
You are very lucky. I had my brakes lock up on my busa doing 50 mph and when I say lock up, they grabbed so hard that the bike instantly went into a low side. I didn't even have a chance to think about what was happening. Bike slid down the road and when I got up off the ground and ran over to the bike, the brakes had hot steam coming off them. It wasn't till they cooled down that I could actually roll the bike to the side of the road.
Pro-Lux-Racing is offline
post #6 of 9 (permalink) Old 04-18-2011, 12:17 PM
evilbear78's Avatar
Motorcycle: 2008 GSXR 600
Same thing happened to me after shorty lever change. When I put the brake lever on, it wasn't seated properly into the recessed area for the actuation of the master cylinder. Check to see if the brake lever is seated over the MC correctly first. I reseated mine, and never had a problem after that.
evilbear78 is offline
post #7 of 9 (permalink) Old 04-18-2011, 07:05 PM
Motorcycle: K7 1000
The levers may very well be the culprit. If the master is engaged at all the fluid intake/return port can be blocked off by the seal itself, if you use the brakes a few times, warm up the fluid it might expand enough to cause enough drag, more heat, more expansion, more drag, more expansion untill they finally lock up. Put your old levers on i bet your brakes will be fine.
Spitz04 is offline
post #8 of 9 (permalink) Old 04-19-2011, 09:46 PM Thread Starter
drewww3636's Avatar
You guys hit the nail on the head. Took the lever off, check the seat. The master rod was majorly not seated properly. Now its all fixed up GLORIOUS!
Now I need to get used to the lever feel ALL OVER AGAIN, F my life.
On that note, my stator cover now has a couple minor paint scratches from the tip. Can I use regular metal paint to touch it up for now? Or do I need to use high temp stuff? I don't know how hot she gets.
post #9 of 9 (permalink) Old 04-20-2011, 12:32 AM
Loves MASSIVE CASCADES of jizz on his face
d207gp's Avatar
Motorcycle: '06 G1K, '08 CBR1000RR, '13 Ducati MTS 1200
Regular paint to touch up the cover should be fine.
d207gp is offline
