07 gsxr 600 Brake issue - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 10 (permalink) Old 06-11-2019, 08:53 PM Thread Starter
Motorcycle: 07 Gsxr600
Firstly the front master brake cylinder recall was 'taken care of' by a reputable local motorcycle shop.
This bike was purchased from a private seller this year, who had the front master recall done at said shop last year. Checked with the shop and they concurred, they replaced the master cylinder.
First day after 5 minutes of riding, the front brakes (left and right caliper) on their own begin applying pressure and slowed the bike to a stop mid corner with my wrist still trying to throttle. I pull over the best i can front brakes about fully locked, and the brake lever is stiff, completely not like it was moments before.
Called the seller and he walked me through how to release the brake pressure. (opening the bleeder valve nearest the master brake cylinder, squeezing the lever than re tighten the bleeder. Worked and it got me home.
Try riding the next day, same issue occurs. I bleed the brakes, and continue on riding the rest of the day brakes working as normal. I let the bike sit over night or possibly two and attempt to ride it again. i hear the brakes start to squeak, and the brakes start slowly applying pressure like it did before.
Did some research online, and attempt to change my brake fluid. went well, fluid was just as clear as the new stuff i'm replacing it with. bike sits over night, test it the next day and the same instance occurs.
Fast forward a few weeks, made an appointment at the same shop which is an hour away. Told them what I've done and that flushing it with my minimal tools didn't solve my problem. They flush the brake fluid with their tools, let the bike sit overnight and test it the next day. working fine. I show up a few days later to pick it up and we can hear the squeaking as he rolls it outside. They solved nothing. I asked if it could be some small piece of gunk lodging itself in a small hole in the master cylinder, and they said probably not it was replaced the year before.
Was not pleased and i drove it home. ( did a wheel to wheel inspection as well and they dropped the cost from $350 to $250) effing sweet deal
on the way out the mechanic suggested i try replacing the brake lines entirely, and if that doesn't work replace the calipers.
Well here i am today, i replaced the brake lines with steel lines with ones that are set up slightly different. Stock lines are rubber or whatnot, and the right line (longer line) runs down from the master cylinder and piggy backs with the left line at the right caliper. Than it travels around to the left caliper.
The new lines are steel and piggy back at the master cylinder, and run down to their respected calipers. I get them up to pressure and go for a test ride. Worked great, for 40 minutes.. The whole time i had been testing the brakes at multiple speeds, being ready for it to do it again. All seems good, get it up to 100mph and when i let off the throttle, the brakes are coming on harder than i've ever braked before at them speeds.
It has to be something wrong with the master brake cylinder right?
Something settles and clogs a small hole, and it acted crazy fast on my steel lines because they have no give when pressure occurs. When the lines were stock, they had give and took slightly longer and didn't brake nearly as quickly and hard.
And the switching of brake lines and new set up, doesn't that debunk the calipers being the issue theory?
they are both slowly seizing up in unison, i can feel equal heat on the discs when these instances occur.
I appreciate any of your thoughts on this, thank you Cheers
Brian Orr is offline
post #2 of 10 (permalink) Old 06-11-2019, 10:56 PM
Hand-Eye Coordinator
MacBayne's Avatar
Re: 07 gsxr 600 Brake issue
I bet $100 that the lever is Chinese.
MacBayne is offline
post #3 of 10 (permalink) Old 06-12-2019, 04:04 AM Thread Starter
You just lost $100 imaginary dollars good sir. not Chinese
post #4 of 10 (permalink) Old 06-12-2019, 08:21 AM
TheGeek's Avatar
Close up pic of your lever and MC.
What you're describing is due to fluid not being able to return to the reservoir. That is likely one of two things. 1) there's debris in the system blocking the port in the MC. 2) The MC piston is not returning to the fully extended position and blocking the port.
For #2, the usual cause is cheap levers.
TheGeek is offline
post #5 of 10 (permalink) Old 06-12-2019, 03:17 PM
See this. Sounds like what you're experiencing.
"Called the seller and he walked me through how to release the brake pressure. (opening the bleeder valve nearest the master brake cylinder, squeezing the lever than re tighten the bleeder."
So he knew all about it when he sold you the bike and never mentioned it?
Except for testing, don't ride it until you get it fixed.
post #6 of 10 (permalink) Old 06-12-2019, 04:32 PM Thread Starter
I was also told by a separate mechanic that crud is most likely blocking the port in the MC. Seems to be the most logical reason behind the brake actions.
The MC is a Nissin, Japanese i believe, and the clutch lever if i had to guess came with it.
I'm a fresh new member, i cant post pics or links yet. laame.
[quote=BillV Sounds like what you're experiencing.
Except for testing, don't ride it until you get it fixed.[/quote]
He did know about it and didnt mention it. classy guy.
I will not ride it again until i get a new MC or clean it if possible. thank you brother
post #7 of 10 (permalink) Old 06-12-2019, 06:22 PM
MacBayne's Avatar
That "mechanic" is a moron. You should get a refund for the work. If you take it in and they tell you "X" part requires replacement, is one thing, not fixing the issue and sending you along is another.
If you bled the system and bled it well, "crud" shouldn't be left in the system.
Before you go buy a new master, take the lever off and inspect the plunger and the plunger hole. Post pics.
MacBayne is offline
post #8 of 10 (permalink) Old 06-12-2019, 06:36 PM Thread Starter
I brought it to them and asked them to not only try to solve the brake issue, but do a wheel to wheel inspection/ diagnosis and get a sticker. I wanted to know everything that was wrong with it that they could find. They charged me $250 after knocking $100 off the cost... I was pissed. Wasted a lot of time AND got a cracked windshield in my wrx on the ride home from my fiance one of the trips there.
I will give the plunger and plunger hole a check, thank you for the suggestion!
Will post pics when i get to 10 posts
post #9 of 10 (permalink) Old 06-13-2019, 06:54 AM
TheGeek's Avatar
So, OP sent me a PM with pics. It's an OEM lever.
So if I had this bike on my lift table with this symptom, here's what I'd do (after visual inspection for the obvious problems):
1) Remove one caliper and try to push the pads apart. Only one place for the fluid to go. If could not, I would remove the lever and try again. It's possible something is wrong with the lever or assembly.
2) If I could push that caliper open, I'd reinstall, pump up the brakes and try the other caliper. It's possible there could be a line blockage.
You said it was both calipers. Are you 100% certain of that? The only facts I have now are that brake rub (a little is normal) is generating heat. The fluid is expanding due to heat and rather than returning to the reservoir is building pressure. What we don't know is why. I really don't think it's a stuck caliper. You'd have constant issues if it was. I highly doubt the OEM lever is the issue, but also don't know who installed the recall kit. It could possibly be the front brake switch holding the lever just slightly closed, or the lever just getting stuck on the pivot (the obvious problems I was referring to).
The sad truth is that brake systems are fairly simple. Any mechanic should be able to figure this out fairly quickly. If they can't, they should have their tools taken away.
Never mistake education for intelligence.
"Don't go ninjain nobody that don't need ninjain" -
TheGeek is offline
post #10 of 10 (permalink) Old 06-13-2019, 11:05 AM Thread Starter
Thank you for your run down on the matter appreciate it buddy!
I'm not 100% on if its both calipers, im just going by basic observations and feel with my fingers. It never happens when im close to my tools or garage of course, but i try to bring tools with me to get out of a bind every ride.
But during my test ride i wasnt using the front brakes so much i would think that they would be That hot. Ive never witnessed my discs that warm before, but then again i dont feel them after every random ride. not smokin but too hot to hold my hand on. The brake lever in the mean time is as stiff as a rock like you said due to pressure.
I agree with you, there are only a few components to the front brake system, this should be fairly simple for a mechanic to diagnose.
