2012 GSXR 750 clutch adjust and slippage - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 5 (permalink) Old 05-14-2019, 10:01 AM Thread Starter
Here is your "R"
Ibidu1's Avatar
Motorcycle: Ibidu1
Just bought a new to me 2012 750, with 18k miles on it. When I bought the bike the clutch was good, I changed the oil and the clutch began to slip after 8k rpms. I have experience with the older 2000-03 750 and that the worm screw at the case cover would just need an adjustment. But on the 2012 theres one in the center and three outer adjustments. Which do I adjust and what direction?
Ibidu1 is offline
post #2 of 5 (permalink) Old 05-14-2019, 07:36 PM
Hand-Eye Coordinator
MacBayne's Avatar
Re: 2012 GSXR 750 clutch adjust and slippage
There should be 3 adjustments. In the engine cover for the slipper, at the lever arm, and at the clutch lever.
What oil did you use? Was it rated JASO MA or JASO MA-2?
MacBayne is offline
post #3 of 5 (permalink) Old 05-14-2019, 08:45 PM Thread Starter
Here is your "R"
Ibidu1's Avatar
Motorcycle: Ibidu1
Castrol 20/40 its rated JASO MA-2
So the 3 adjusters those adjust the tension on the clutch packs and not the reverse of the slipper clutch. Do I back out the screws a bit and retighten
Ibidu1 is offline
post #4 of 5 (permalink) Old 05-15-2019, 11:07 PM
MacBayne's Avatar
'12 is the same as '06
MacBayne is offline
post #5 of 5 (permalink) Old 05-16-2019, 08:44 PM Thread Starter
Here is your "R"
Ibidu1's Avatar
Motorcycle: Ibidu1
Just what I needed thank you!
I only have experience with older 2000-2005
Ibidu1 is offline
K6 750 clutch problems TMaverick87 Mods & How To's 1 10-17-2010 10:11 PM
2007 Slipper clutch set? did your dealership do it? Squid4Life GSX-R1000 General Forum 24 03-23-2007 05:52 AM
Found some clutch adjustment in K5 MP GSX-R1000 General Forum 1 10-14-2005 05:26 PM
2004 GSXR Clutch Adjustment (Please Help) NoSkills GSX-R1000 General Forum 5 03-30-2005 02:39 AM
