750 No Power at All - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 6 (permalink) Old 04-20-2019, 11:10 PM Thread Starter
750 No Power at All
I have 06 750 Gsxr . I have checked everything under the seat to fuses even went to the manual to check connections and fuses . Battery and fuses are good . i cant seem to figure out the problem with the bike .
AquaGod_09 is offline
post #2 of 6 (permalink) Old 04-20-2019, 11:20 PM
Currently using pedals..
tatersalad314's Avatar
Motorcycle: L5 600
Re: 750 No Power at All
Have you tested the kill switch?
Please, go introduce yourself in the "Starting Line" section...
tatersalad314 is offline
post #3 of 6 (permalink) Old 04-22-2019, 04:38 AM
I will assume that "no power at all" means the dash, lights, etc. don't come on. Have you tested the 30A main fuse?
post #4 of 6 (permalink) Old 04-22-2019, 08:05 AM
TheGeek's Avatar
How exactly did you test the battery?
TheGeek is offline
post #5 of 6 (permalink) Old 04-22-2019, 06:46 PM
JamesIsMe's Avatar
Need more info. Does it not power on when key is turned to on position? Cant get it to start?
JamesIsMe is offline
post #6 of 6 (permalink) Old 04-22-2019, 09:05 PM
Hand-Eye Coordinator
MacBayne's Avatar
Motorcycle: 2014 675R, 2019 Husky TE300i
When you say battery is good, you mean well above 12.5V at rest, right? When you say fuses are good, you used an ohmmeter or continuity test, right?
Have you looked to see that the terminals are on the correct side and that the battery leads are solidly connected on both sides?
With the key on and using a voltmeter, you confirm that there is no power to anywhere on the machine? Turn the key on and test the voltage between the poles on the starter relay.
MacBayne is offline
HELP 06 750 low power GixxerGianni 06-07 GSX-R600/750 40 11-04-2008 06:17 PM
93 Gsxr 750 No power!? hrdkrtazz Water Cooled Gixxers 23 09-26-2008 09:58 PM
2005 750 hindered power Gixxykid 04-05 GSX-R600/750 27 07-29-2008 08:08 AM
750 with more power than 1000 daveysrad Extreme Performance 41 10-20-2006 12:32 PM
2006 Open Superbike Shootout , GSX-R1000 Still on top. Fromundacheese GSX-R1000 General Forum 22 03-16-2006 10:10 PM
