What oil do you run? - Page 3 - Suzuki GSX-R Motorcycle Forums Gixxer.com
 11Likes
post #41 of 48 (permalink) Old 04-25-2018, 11:26 PM
Re: What oil do you run?
Just came across this:
Taken at face value, you shouldn't be using Rotella in K7 up unless you've removed the cat. I gather that the issue is the high phosphorus level.
However the problem that I have with this is that Rotella is widely sold for use in cars, which have had catalytic converters for aeons. You'd think that there would have been an uproar from those owners by now if the issue was real. Nonetheless this is coming directly from Shell. Go figure.
post #42 of 48 (permalink) Old 04-26-2018, 12:43 AM
Carlos67's Avatar
Motorcycle: 2018 GSXR750L8 Metallic Triton Blue
Came across this last week. Testing done by Amsoil so you could hardly call it independent but where I found it useful is in the comparison between the OTHER oils in the test.
Its getting a bit old now but still useful information.
http://assets.ngin.com/attachments/d...cycle_Oils.pdf
Carlos67 is offline
post #43 of 48 (permalink) Old 11-18-2018, 07:24 AM
Originally Posted by MacBayne View Post
What does your manual say? Only the manual knows best.
Use whatever weight is recommended in your manual (10-40 for me) then get synthetic. The weight should match the manual because these are high-revving, low-tolerance engines.
Superbike Racer is offline
post #44 of 48 (permalink) Old 11-18-2018, 11:56 PM Thread Starter
ComponY's Avatar
Interesting find! I definitely didn't have a cat, nor usually run one on any bike, but still good news to share!
gcuntmor likes this.
ComponY is offline
post #45 of 48 (permalink) Old 11-19-2018, 01:18 PM
Here's some similar info from a non-Shell source. An independent test of Rotella T 15W-40 found the phosphorus level to be 965 ppm vs 600-800 ppm for API SN (introduced in 2010).
P.S. BobIsTheOilGuy is a better source but I think what's going on is that phosphorus is not being added for it's own sake but is a side effect of adding zinc as an anti-wear additive in the form of zinc dialkyldithiophosphate (aka ZDDP). The adverse effect on catalytic convertors is forcing the oil manufacturers to take other routes.
post #46 of 48 (permalink) Old 11-20-2018, 07:07 AM
TheGeek's Avatar
But read what the phosphorus is good for..... F-the converter...
TheGeek is online now
post #47 of 48 (permalink) Old 11-29-2018, 04:37 PM
JP1143's Avatar
Motorcycle: K4 1143, L2 1K
Clean oil is best oil!! Change it like you change underwear and you will never have an issue.
JP1143 is offline
post #48 of 48 (permalink) Old 07-14-2019, 10:52 PM
Rotella and motul, are good, mobil is descent, put amsoil in my L7 750 for oh 3 blocks. Every Body on here seems to be infatuated with AM soil but when you pour it in it looks like the crapped that comes out of my bike after I've given it a hard run. If you really wanna see some crazy stuff going down your funnel get Castrol 4 stroke GTX. When the bottle is about out of oil the drips will hit the funnel in explode in 2 small little oil ball bearings. It's specifically designed to stick to your parts because we all know these bikes are a noisy start already and so a Lucas like film is good to have. I had a 2006 750 that I started the Castrol Around 12:00 miles and it runs better than my 2017 Does at its current 1400 miles. And that's why I'm ordering it off the Internet now. It's a semi synthetic so it will keep your rings nice in juicy and these transmissions seem to really enjoy swimming in it also. Just my experience
bjoshua1002 is offline
