4500-5000rpm convulsions / stutter (GSXR 1000 L0) - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 8 (permalink) Old 04-02-2014, 02:03 PM Thread Starter
Motorcycle: GSXR 1000 L0
I know there are a couple forums open on this and I have had a read of them but did anyone actually find the final fault or the best course of action when I went into the dealer the said they didnt know and would just put it on the computer and see if anything has been logged?
When I get into the 4500-5000rpm range (sometimes a little higher or lower) the bike stutters or convulses the power drops off completely and the engine braking slows the bike down, then i jumps back on the power.
No FI light so no point putting it in dealer mode. What happens at about this rpm range that would make it different than higher/lower as it doesn't happen outside of those ranges.
davehowie22 is offline
post #2 of 8 (permalink) Old 04-02-2014, 05:07 PM
Re: 4500-5000rpm convulsions / stutter (GSXR 1000 L0)
Sounds like: CLOGGED INJECTOR(S).
Or bad plugs.
nightrain is offline
post #3 of 8 (permalink) Old 04-02-2014, 08:28 PM
Motorcycle: 2011 1198SP, 2011 848EVO
Check out this old thread:
https://www.gixxer.com/forums/showthread.php?t=300963
My post is #11 and it may help with your problem. Good luck
Gary
Sent from Motorcycle.com App
FlWolverine is offline
post #4 of 8 (permalink) Old 04-03-2014, 06:08 AM Thread Starter
Thanks nighttrain im going to pull all that part out this weekend. But strange that it happens at that rpm range only
post #5 of 8 (permalink) Old 04-03-2014, 06:20 AM Thread Starter
Gary
Cheers mate ill this too. I have not tinkered with my bike though it just started happening and been getting worse.
post #6 of 8 (permalink) Old 04-21-2014, 03:34 AM Thread Starter
Hey guys so I did an oil change on the bike and it fixed those problems...
Any idea on how that would help the situation.
I'm lost (but quite happy).
post #7 of 8 (permalink) Old 05-19-2014, 02:56 PM
Was the oil overfilled? Some have posted weird issues when that's happened. Was the airbox and filter clean? No residue?
v6stanger is offline
post #8 of 8 (permalink) Old 05-20-2014, 09:05 AM
strange I just had this issue on the ride home from work sunday. oil light was on only at stop lights, So I will be pulling plugs, and doing oil change to see if it fixes issue. I thought it may be bazzazz box but everything seemed to be ok with that..ill update you guys
ColdCapo is offline
