2009 GSXR 1000 Bazzaz map needed with .018 Head Gasket - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 4 (permalink) Old 08-13-2013, 02:00 PM Thread Starter
2009 GSXR 1000 Bazzaz map needed with the following performance mods:
.018 Head Gasket
BMC race filter
M4 Street Slayer Exhaust
Anyone have anything I can throw at this bike?
davdoc0011 is offline
post #2 of 4 (permalink) Old 08-13-2013, 02:29 PM
JP1143's Avatar
Motorcycle: K4 1143, L2 1K
Re: 2009 GSXR 1000 Bazzaz map needed with .018 Head Gasket
Good luck with that. People pay $300+ for a custom map, so don't hold your breath waiting for someone to send you one for free. Not being a dick, but thats just the reality of things.
I have a brand new 1K with similar modes mines the head gasket and the Bazzaz has two maps loaded, a stock map and a slip-on map. The slip-on map seems to work well. Theres no hesitation anywhere in the rpm range or when blipping the throttle like you normally see. I have the map switch mounted on my handle bar which makes things easier. Get that switch.... only $70.
K4 1K, ported head perfected by Jim Cambora, 76mm JE 13.5:1 pistons, Carrillo A rods, RC's 4mm crank, Akrapovic exhaust, Yosh STR-R int cam, 750 int on ex, billet basket w/JetSpeedz clutch mod, Brock clutch cushion, Koenig 1.5' billet pan, PC mapped by RaceworX, BST wheels/titanium pin kit, Afam sprockets/DID chain, Pipercross filter, NGK plugs, speedohealer, billet v-stacks, FP levers, APE head/case studs, Galfer rotors/ lines, suspension by Cambora, Vortex r-sets gp shift, ceramic bearings
JP1143 is offline
post #3 of 4 (permalink) Old 08-13-2013, 02:43 PM Thread Starter
I have the switch installed. I have a few other bikes with custom maps..just looking to see if there was something I could try.. Whats your bike make?
post #4 of 4 (permalink) Old 08-13-2013, 06:01 PM
Karns Performance's Avatar
Motorcycle: 05 1k- sold / 2012 1k
i hope you degreed the cams if you installed a .018 head gasket.
and if you did it right. the fueling will be off enough to NEED a custom map.
jason
Karns Performance is offline
