K5/K6 ignition immobilizer - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 5 (permalink) Old 05-15-2019, 08:53 PM Thread Starter
Hi, I am in Australia and have a 2005 GSXR 1000.
I have a USA spec flashed ECU to fit on the bike but need help/advice on how to disable they key/ignition barrel from trying to receive a signal from the USA spec ECU that doesn’t have an immobilizer function.
Regards,
Mark.
adelaidegsxr is offline
post #2 of 5 (permalink) Old 05-16-2019, 12:30 AM
Re: K5/K6 ignition immobilizer
It's the other way around. The ignition switch sends a signal to the ECM.
The cleanest way is to replace the ignition switch and wiring harness with E33 parts. You're probably trying to avoid that. Have you considered flashing the ECM to the E24 spec? There are other ways but they're a bit cludgy.
If you want to maintain the E33 anti-theft feature, you need to run a line from the ignition switch's O lead to a 100 Ω resistor and a lead from that to ECM pin 21. You're going to have to buy a suitable JAE female contact. I'm not sure but you may be able to leave the second ignition switch connector in place. If not, disconnect it. Similarly, I don't think it matters that the Br/Y lead from ECM pin 44 runs to the cluster. But disconnect it if the light in the cluster acts up (and plug the empty hole with the leftover dummy plug from pin 21).
A simpler way (I think) is to run a 100 Ω resistor from ECM pin 17 to pin 21. But you lose the anti-theft feature by that.
post #3 of 5 (permalink) Old 05-16-2019, 01:10 AM
-JK750-'s Avatar
Motorcycle: K5 1000 & K1 750
It's simple, modify the harness like this.
-JK750- is offline
post #4 of 5 (permalink) Old 05-16-2019, 06:16 AM Thread Starter
Hi, I am looking for the easiest way to have the key/ignition barrel not need to communicate with an ECU that does not have the function to do so(USA already flashed).
I have a picture of the 2 plugs from my current ignition, do i not touch these and just place a resistor at the pins you mentioned at the ECU even though it is a USA model(non immobilizer).
Could I use a USA type ignition and key(cheap from China on Ebay) or will the wiring some how interfere as there is only one wiring plug on USA model ignition where my Australian bike has 2 pugs looks like a 4 pin and (8pin with 7 wires)
I am not a professional so pardon me if I am slow on working out the easiest way for me to remedy this without wasting the USA ECU and sending my ECU to get flashed(more expense).
Regards,
Mark.
post #5 of 5 (permalink) Old 05-16-2019, 06:51 AM
A E33/US type ignition switch has (or should have) a built in resistor and an extra line from it (probably O/Y). You'd have to buy a mating six pin connector, move the four leads from your existing four pin to it, and run a line from the new lead to ECM pin 21. Leave the other four pin connector unconnected.
ignition curve modification (I miss my pcii) jassing SRADs (97-00 600 and 96-99 750) 16 08-02-2017 06:45 AM
Ignition Swap Issues Nust08 01-02 GSX-R1000 8 06-24-2016 07:06 AM
K6 k7 Keyless Ignition grass cutter 06-07 GSX-R600/750 3 04-02-2009 01:01 PM
ignition module and quickshifter install proplems 02GIXXER GSX-R1000 General Forum 4 09-03-2008 09:11 AM
? about my Dyna 2000 performance ignition TheMANN Water Cooled Gixxers 8 01-19-2004 04:11 AM
