Engine turning off while riding - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 10 (permalink) Old 04-19-2019, 07:52 PM Thread Starter
Hello everyone new in the forum my bike is a 2003 gsxr 1000 I had it for about 7 year. Last year while riding the engine turn of at 6000 rpms as soon goes down that 6000 turn on again does not let me past 6000rpm in any gear , I had switched the fuel pump, eliminated the SET. I will appreciate any help to find out what is wrong thanks
Ftarqui is offline
post #2 of 10 (permalink) Old 04-19-2019, 10:36 PM
Currently using pedals..
tatersalad314's Avatar
Motorcycle: L5 600
You switched the fuel pump, but did you test either of them?
tatersalad314 is offline
post #3 of 10 (permalink) Old 04-20-2019, 01:27 AM
Re: Engine turning off while riding
Does it bog down or is there a sharp cut-off at 6000?
I'm thinking kickstand switch, secondary throttle, or fuel filter but we need more information.
post #4 of 10 (permalink) Old 04-20-2019, 05:15 AM
nosurrenda's Avatar
I'm gonna say he put the fuel line on back to front, 'cos that's what I did once and got the same symptoms.
nosurrenda is online now
post #5 of 10 (permalink) Old 04-23-2019, 12:22 PM Thread Starter
Hello, yes I tested the fuel pumps and the line, replace fuel filter. Now the bike as soon reach 6000RPM it does bog down and after several seconds turn on again while is doing this shows a check on the screen but went I put it on dealer mod is not giving me codes at all just -C00 thanks
Ftarqui is offline
post #6 of 10 (permalink) Old 04-23-2019, 03:00 PM
closetotheedge's Avatar
Motorcycle: K4 1000 K6 1000
I had a similar problem recently, I posted I thought it was the pump but I should have posted filter. I couldn't be bothered stuffing around changing a filter so I covered all bases and installed a new pump and filter.
I reckon that paper filter causes big problems as they age.
closetotheedge is offline
post #7 of 10 (permalink) Old 04-23-2019, 03:05 PM
"while is doing this shows a check on the screen but went I put it on dealer mod is not giving me codes at all just -C00"
That's because you're shutting the bike off to put it in dealer mode. That causes the codes to be cleared. You must keep it running. One way is to locate the switch where you can reach it without turning anything off. If you're certain that you're not experiencing any overheating issues, you can just leave it in dealer mode while you ride.
How did you test the fuel pumps? You should have performed a flow rate test as is described in the service manual.
"replace fuel filter" Which one, the strainer at the bottom or the real/main filter?
post #8 of 10 (permalink) Old 04-24-2019, 09:47 AM
Originally Posted by Ftarqui View Post
... while is doing this shows a check on the screen but went I put it on dealer mod is not giving me codes at all just -C00
I read that as "the dash shows CHEC while the bike is bogging down". If that is the case then it makes Bill's "faulty kickstand switch" (or similar electrical/wiring failure) more probable.
post #9 of 10 (permalink) Old 04-24-2019, 12:16 PM
Kartel's Avatar
Motorcycle: GSX-R1000 K4
When my spring of the kickstand got loose my bike could cut off but not at any particular rpm, it was just intermittent, once the soldering where alarm was put into the circuit caused similar problems but again not at any particular rpm...
Kartel is offline
post #10 of 10 (permalink) Old 04-24-2019, 12:31 PM
Likes Diiiiiiiiiiiiiiicks
Did you actually replace the filter, or are you calling the strainer on the fuel pump the filter? Because it's not.
And what actual diagnostic steps did you do before deciding to just throw in the pump?
bought '05 Gsxr 600 yesterday, started dying after turning off, then riding DMacK24 04-05 GSX-R600/750 8 06-20-2016 04:55 AM
2nd gear slipping... I'm pulling the engine and going in! ShawnColorado 01-03 600 and 00-03 750 24 11-16-2015 06:14 PM
Urban Guerrilla... Riding in Traffic (daily commute) Beaker The Starting Line< ======= 2 05-04-2008 02:17 AM
Anticipation - start of the season superflytnt Club Racer 29 01-29-2004 12:39 PM
OK, the skinny on engine break-in(Long) fun2fly F.A.Q. 8 05-01-2002 11:05 PM
