ECU Flash More HP $75.00 !! - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 6 (permalink) Old 08-23-2014, 01:10 AM Thread Starter
Dano's Performance ECU Flashing Services
Dano's Performance now offers ECU flashing services for the many late model Suzuki motorcycles. This service is only available to our U.S. customers. Our ECU flashing service removes all the required emission restrictions programmed into the ECU from the factory. These restrictions greatly hinder the engines performance and throttle response. We will optimize both the ignition curve and the fuel curve which will unleash hidden horsepower from your engine. This mod alone will all but eliminate the need for a Power Commander, TRE and ignition module. Please see our website for all the details of all the features available at: http://www.danosperformance.com/ECU%20Flashing.htm
Dano316 is offline
post #2 of 6 (permalink) Old 08-23-2014, 01:50 AM
-JK750-'s Avatar
Motorcycle: K5 1000 & K1 750
Re: ECU Flash More HP $75.00 !!
"Suzuki GSXR 1000 - (2007-11)
Remove secondary throttle plate limits (this adds more top end horsepower)"
So the plates can be opened more than 93.3? Can they be set to 95, same as on a K5-K6?
-JK750- is offline
post #3 of 6 (permalink) Old 08-24-2014, 01:44 PM Thread Starter
On the model that is as far as they can be opened.If they could be opened more there still won't be any horsepower gain since they are already opened wide enough.The two areas where more performance can be found on that model is the ignition timing and the fuel curve. Thanks Dan
Dano316 is offline
post #4 of 6 (permalink) Old 09-26-2014, 11:58 PM
Motorcycle: Million Edition GSXR1000
Hey Dan
Can you make exception to your Canadian neighbours? I have a US mailbox in Washington state if that helps. Also, can I get this done to my stock L3 gsxr1000 prior to installing an Akrapovic full exhaust with PCV (winter project) or do you recommend to installing the mods first then flash the ECU.
Thanks
ProPs is offline
post #5 of 6 (permalink) Old 09-27-2014, 08:19 AM
Motorcycle: K4 600
How come a ton of aftermarket or mods I find always start with the 06-07 models and up. I feel like my 04 is missing out lol
Youngmoney23 is offline
post #6 of 6 (permalink) Old 09-28-2014, 11:37 AM Thread Starter
I would recommend flashing the ECU first so that when you install all the aftermarket items the final tune will be correct. Thanks Dan
Dano316 is offline
