ECU flash with Quick Shifter $260.00 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 2 (permalink) Old 10-10-2013, 07:09 PM Thread Starter
Suzuki GSXR 1000 - (2007-11)
Optimize fuel curves across all gears (similar to a Power Commander)
Optimize ignition curves across all gears (same as our GP-TRE)
Disable Pair Valve
Remove top speed limiter
Disable Steering Damper function (If adding an aftermarket Damper)
Enable hard cut RPM limiter
Remove secondary throttle plate limits (this adds more top end horsepower)
Enable Quick Shifter function
http://www.danosperformance.com/ECU%20Flashing.htm
Name:	GSXR 1000-QS.jpg
Dano316 is offline
post #2 of 2 (permalink) Old 10-11-2013, 01:07 AM
Frame Slider Tester
VooDoo Child's Avatar
Motorcycle: L1 1K
Re: ECU flash with Quick Shifter $260.00
does it come with stickers?
VooDoo Child is offline
