F3 Engineering Mark 1 "magnetorheological fluid" Steering Damper 65% off GB BLOW OUT - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 2 (permalink) Old 10-30-2012, 11:25 AM Thread Starter
Motorcycle: 07 GSX-R1000, . OHLINS_MASTER_DEALER
Yea, you read it correctly.
As much as 65% discount on these Dampers.
They Retail for nearly $850
But, Now you can get one for nearly 1/3 rd the price.
This uses similar technology to the Magnetic Shocks in the New Ferrari's, Corvettes, and Caddy.
LED's show you how much dampening.
Easy to adjust with 2 Buttons. ONE UP and ONE DOWN.
Installation is very easy. Only needs to be wired to 12v. Power.
Post up, or PM For Bike Specific Pricing.
* F3 Engineering Electronic Dampers are CNC machined from aircraft-grade aluminum with a carbon fiber cover
*Semi-active with 8 damping settings
*Uses magnetorheological fluid technology
*Incoorporates anti-tank slap (ATS) circuitry to provide additional damping at the onset should a tank slap begin
*Self-adjusting response reduces rider fatigue and improves steering
*Kit comes complete with wiring harness, yoke mount and all necessary hardware for a complete and easy installation.
From F3 Engineering.
No matter the track conditions, no matter the road conditions, no matter the weather conditions, you’re out to motor on your bike as fast as man and machine possibly can. And we’re out to help – bringing a whole new level of control to the serious rider.
Using our exclusive magnetorheological fluid technology, and a closed loop control system, the Mark I Steering Damper immediately adjusts to adverse conditions, reacting to shock and vibration in under one millisecond, eliminating virtually all instances of head shake, and conditions that can cause tank slapping.
Reacting in real time, the Mark I Steering Damper gives you full-throttle confidence and control under any conditions.
Mark 1 Steering Damper
F3 Engineering has applied its magnetorheological fluid-based shock and vibration technology to a new commercial product: a steering damper for high-performance motorcycles. Forming a separate company named F3 MotorSports, it has teamed with 14-time Grand Prix National champion, Mike Himmelsbach and most recently with the Aprilia USA motorcycle team, to continue development of the Mark I steering damper.The Mark I steering damper addresses the specific vibration and steering control issues faced in high performance racing.
This F3 technological breakthrough was originally developed through a SBIR program awarded by Naval Air Systems Command (Navair) for the design and development of a side lateral engine mount for the E-2C Hawkeye aircraft. This engine mount mitigates both the harmful vibration caused by the plane’s turbine engines and the shock caused by carrier landings. F3 Engineering took this SBIR through to a Phase III.
HardRacing is offline
post #2 of 2 (permalink) Old 10-30-2012, 04:31 PM Thread Starter
Re: F3 Engineering Mark 1 "magnetorheological fluid" Steering Damper 65% off GB BLOW
Lots of PM's. Sorry was not clear on the MODELS Offered.
06-07 GSXR600
06-07 GSXR750
07-08 GSX-R1000
02-08 RSV1000
