ECU Flash and Quick Shifter $300.00 !!!! - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 1 (permalink) Old 10-28-2012, 04:19 PM Thread Starter
Danos Performance now offers ECU Flashing for the Suzuki GSXR 1000 2007-11 models which includes a Quick Shifter for only $300.00 complete.
Optimize fuel curves across all gears (similar to a Power Commander)
Optimize ignition curves across all gears (similar to a TRE)
Disable Pair Valve
Reset radiator fan turn on/off temperature
Remove top speed limiter
Disable Steering Damper function (If adding an aftermarket Damper)
Enable hard cut RPM limiter
Enable Quick Shifter function
See our website for all the details at:
http://www.danosperformance.com/ECU%20Flashing.htm
Name:	GSXR 1000 kit.jpg
Dano316 is offline
