yeah clears the filter even with the 750 oil cooler,cons?
it's alittle too long, sticks out past the rear wheel. I'm thinkin of shortening the CF can.
Bobbychet
ya, now that i look at your sig i can see that. ya, either cut the can or have someone make a new mid pipe. there is a new rs3 system on ebay for 6 something. i am just always looking for a fall back. i go on vacation next week and when i get back i plan to cram on the bike to get it done. i bought a drill press just to drill the heads of the allen bolts so i could put the eaxhaust springs on to help with the leaks. i realize the system will always have some kind of leak, i just dont want one of those super audible leaks.
so you got new flanges or just straighten out the old ones? also after you put the exhaust gaskets in, fit the header and find a high temp header sealant or super thin sheets of lead and press and form that around the pipes to prevent leakage,then tighten down the flanges to keep it in place.A high temp "O" ring made out of asbetos would be the ticket.
Just some ideas.
Bobbychet
no i did not get any spigots, i was just thinking about extras more than anything. after i taped the tubes into the spigots, it greatly reduced the leak. at that point i still had not put the springs on. so hopefully the springs will help a bit more.
I got 2 so far, gixer1146 was supposed to send me a 1100 swingarm but nothing so far.I've also bid and won another 1100 swingarm on e-bay so I guess I'll start hoardin them too.
Bobbychet
If it fit's an SV than it will be longer than our's. I suppose you could make it fit. I have an SRS link not mounted into bike yet if someone want's to do the copy thing. I also have a Fox shock that needs a new home...:biggrin
probably 280 right now. i plan to back on my diet after our vacation, so that should drop soon. i will let you know after the trip tuner, if i have any damn money left.
