94 gsxr 750 - Suzuki GSX-R Motorcycle Forums Gixxer.com
  • 1 Post By Bufftester
post #1 of 4 (permalink) Old 03-01-2019, 10:36 AM Thread Starter
94 gsxr 750
Hey everyone I have a 94 gsxr 750 I'm trying to change the front turn signals to leds I installed load resistors and they still don't work I tested the lights and they do work hooked to a battery but to the bike they do not. Do I need to replace the turn signal flasher for a led one? Please help
Kyle Hudock is offline
post #2 of 4 (permalink) Old 03-01-2019, 10:45 AM
The Supermod that wants to see grandma's Snapper....
Ironhead401's Avatar
Motorcycle: WR250R
Re: 94 gsxr 750
Wrong section. We have bike specific sub sections for every GSXR, including yours. READ and post in the correct section, you'll get more responses. I moved it for you.
Ironhead401 is offline
post #3 of 4 (permalink) Old 03-01-2019, 06:10 PM
Juvenile Thinker
Bufftester's Avatar
Re: 94 gsxr 750
Did the front signals work before you swapped them? If you put in the correct load resistors you shouldn't need to change the flasher unit. Check the fuse for the turn signals.
Ironhead401 likes this.
Bufftester is offline
post #4 of 4 (permalink) Old 03-04-2019, 09:15 PM Thread Starter
Sorry I'm new here yes the old turn signals worked fine the fuse is good maybe I need a higher amp load resistors? I think the ones I got we're 6amp
88-92 750 and 89-92 1100 Parts Interchange Info Bones_GSXR Oil Cooled Gixxers 158 01-28-2018 07:28 AM
Updated Parts Interchange: 88-92 750 and 89-92 1100 outlanderlet Oil Cooled Gixxers 1 10-12-2007 06:48 AM
Motor swap for 95 GSXR 750 help needed kcc0521 Water Cooled Gixxers 16 08-24-2004 11:52 AM
01-03 GSXR 750 to 04 GSXR 750 front end conversion masa523ser 04-05 GSX-R600/750 3 06-15-2004 08:13 AM
