1998 GSXR 1100 issues (Stumped) - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 11-28-2017, 07:56 PM Thread Starter
Question 1998 GSXR 1100 issues (Stumped)
I'm gonna do my best to make this long story short. I've got a California model 98' 1100W that has but 10,00 miles on it. The bike is completely stock with the exception of a yoshi pipe and is having what i believe is some carb problems and this is where I am at now.
It idles fine and runs great above 6k rpm's, however it struggles to take off and go in the lower rpm range. This also only affects the bike when there is a load on it because it rev's fine.
I feel like it's a jetting issue, and maybe it's the main jets? i'm honestly stumped. I synced the carbs with the motion pro carb sync tool and feel like they are synced pretty good. If anyone can help that would be great because I am feeling pretty stumped
edmyser is offline
post #2 of 3 (permalink) Old 12-08-2017, 05:30 AM
Re: 1998 GSXR 1100 issues (Stumped)
is this happening when hot or even during a cold start.
i presume there is no issue in neutral and high rev, issue pops out say around 1.5-3K rpm it struggles and needs more throttle ? if so few things worth to check,
cable play - you have a adjuster near to the throttle which you need to adjust to zero down the play. Blocked/Partially blocked filter - clean with air, if KN use their solution to lube them.
fuel line - check them thoroughly
Jets - as you doubt, there are chances of the pilot jet being clogged, use a can of seafoam
check Plugs, plug caps (5K resistance should be there if you using R plug),Plug wires - trim the end of the plug wire and re-screw to the plug adapter
coils - check the reading of both coils if they throwing desired output (there are threads in this forum on how to check)
twinhead is offline
post #3 of 3 (permalink) Old 12-11-2017, 02:58 PM
Juvenile Thinker
Bufftester's Avatar
Sounds like a pretty standard jetting issue. Not on your mains though, but in the pilot/idle circuit.
Bufftester is offline
