96 gsxr 1100 normal compression? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 04-17-2017, 06:28 AM Thread Starter
Hey guys, what is the normal compression for a 96 gsxr 1100?
SubZero709 is offline
post #2 of 3 (permalink) Old 04-17-2017, 08:58 AM
IM THE BRONZE
Re: 96 gsxr 1100 normal compression?
As per manual, the standard is between 170lbs-199lbs.
If it's low check valve adjustment and look for tight valves.
If low and valves are good, add some oil in the cylinders and check comp again.
If it raises after oil, you got stuck or worn rings/cyl. issues.
Geesxara is offline
post #3 of 3 (permalink) Old 04-22-2017, 05:55 AM Thread Starter
Thanks
