97 GSXR 1100 rear shock replacement/upgrade - Suzuki GSX-R Motorcycle Forums Gixxer.com
 2Likes
  • 1 Post By thaetviking
  • 1 Post By racerguy36
post #1 of 6 (permalink) Old 02-08-2017, 07:51 PM Thread Starter
Trolling through all the forums I see a lot of recommendations for the 07/08 GSXR 1000 rear shock as a replacement. I did see in the oil cooled section some guys have gone with a BMW S1000RR since it is a direct replacement. I was wondering if anyone has tried that on a 93-98 with success and what mods were needed? or I am just better off going with the 07/08 GSXR 1000 rear shock? I am not doing the replacement myself so I need to know if there is something out there my mechanic can just drop in without any mods.
TJS likes this.
thaetviking is offline
post #2 of 6 (permalink) Old 03-28-2017, 01:07 PM
Re: 97 GSXR 1100 rear shock replacement/upgrade
Curious about this too. Any posts about the 07/08 1000 direct shock replacement?
ryandcramer is offline
post #3 of 6 (permalink) Old 03-28-2017, 07:37 PM
TJS
TJS's Avatar
Easy to change out with some basic tools!
If you don't have solid mount foot pegs, run a steel bar through the swing arm axle.
TJS is offline
post #4 of 6 (permalink) Old 03-28-2017, 07:49 PM
TJS
TJS's Avatar
Stuff to help you learn:
1. Get you Red R
2. Fiche: Motorsports Honda Yamaha Suzuki Kawasaki Motorcycle Dealer ATV Greenville NC Used Sport Bikes Eastern North Carolina Hustler mower, Honda Power equi
3. Get a book: 1992-1995 SUZUKI GSX R750W MOTORCYCLE SERVICE MANUAL & BINDER/ 99500-37073-03E | eBay
4. Get another book: https://www.amazon.com/Suzuki-Katana...sxr+750+haynes
5. Carb help and parts: (but I say keep the 39 FCRs) CV Carb Tuning Procedures
6. Carb parts for cv and fcr (wiil need float needle from other supplier): LiteTek
7. Get on youtube: https://www.youtube.com/channel/UCBh...T3qXwTW0eToyCg
TJS is offline
post #5 of 6 (permalink) Old 03-31-2017, 11:40 AM
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
F.W.I.W...I have never been a fan of shoehorning a another bike or brands shock into a Gsxr simply because the bolts holes line up.
Incorrect valving, incorrect springing, incorrect ride height and the list goes on.
Will most anything be an improvement over a sagged and shagged 25+ year old shock?
The answer to that, of course is yes!
Is it the proper way to proceed in the pursuit of upgrading your suspension?
I.M.H.O. it is not!
Find an Ohlins shock...find a Fox shock...find a Progressive shock...Find a Works Performance shock but for God's sake find something that is actually built for your application!
THE SRADIATOR is offline
post #6 of 6 (permalink) Old 05-11-2017, 07:52 PM
racerguy36's Avatar
I just installed a rear shock from an 07 GSXR 1000 on my 93 750W, took a little longer than I thought but it was pretty easy to do, had lots of room for the new one, and everything lined right up.
My suggestion, after removing the old unit, loosen all the links and install the top bolts first. Get the bike high enough so when you go to install the bottom bolt, you can lower the swingarm an extra 8"-16". It will make things easy.
Adjust the settings on the new one and go for a test ride with a small flat head screwdriver so you can stop and adjust it on the road.
knowyourenemy66 likes this.
racerguy36 is offline
