'91 1100 suspension questions - Suzuki GSX-R Motorcycle Forums Gixxer.com
  • 1 Post By Doc_Rot
post #1 of 3 (permalink) Old 05-01-2019, 10:45 AM Thread Starter
I found a Ohlins s1000rr shock. I believe I have read the swap info correctly and got the correct shock. Here's my questions:
1. Does the Ohlins need to be modified (spring, shims, valves) to work properly for the bike? I know the spring has to be for my weight but what about the rest?
2. What shop in the US would be best suited to do the work to the shock?
3. At the same time I want to send the forks off to be rebuilt and modified with upgrade valves and shims. What shop in the US would be best suited for this work?
Thanks
Seattle Slabside is offline
post #2 of 3 (permalink) Old 05-02-2019, 01:11 AM
Doc_Rot's Avatar
Re: '91 1100 suspension questions
Race tech is a one stop shop for all your above questions. you probably will need to revalve the shock for your geometry.
Beairsto Racing likes this.
Doc_Rot is offline
post #3 of 3 (permalink) Old 05-02-2019, 11:08 AM Thread Starter
I haven't had the same experience with them. When I've called them in the past I was told things like
"I don't know"
"we don't have that in our records so just send it and maybe we can work on it"
The one time I did use them they told me 2 weeks turn around an it was 2 months of me calling and getting the run around before I got my stuff back.
88-92 750 and 89-92 1100 Parts Interchange Info Bones_GSXR Oil Cooled Gixxers 158 01-28-2018 07:28 AM
'95 GSXR 1100 exhaust questions wildturkey Water Cooled Gixxers 2 06-22-2013 06:34 AM
GSXR 1100 rear shock questions forkspear Water Cooled Gixxers 4 03-16-2012 09:47 AM
wiring questions - 750 & 1100 help needed stockgp Water Cooled Gixxers 3 10-07-2011 01:15 AM
Help: Need accurate suspension measurements 89 1100 freewilly Oil Cooled Gixxers 5 08-10-2010 03:33 PM
