92 Gsxr 1100 rear brake bleeding question - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 6 (permalink) Old 04-16-2019, 08:42 PM Thread Starter
dontilgon1's Avatar
Motorcycle: 1992 GSX-R 1100 1994 GSX-R 750
I completely drained the system took it apart and blew out the lines needless to say it was pretty dirty. After I put everything back together I did not see any bubbles in the rear brake reservoir while pumping the brake pedal. I was using the bleed screw on the front only. iím not getting anything. I tried to vacuum and also wasnít pulling although when I put air into the bleeder screw bubbles came up to the reservoir. I just noticed a Another bleeder nipple on the other half of the caliber do I need to bleed this side also. Could this be the problem or is it the master cylinder. Bike only has 5100 miles
dontilgon1 is offline
post #2 of 6 (permalink) Old 04-19-2019, 05:06 AM
Motorcycle: GSXR1100 M
Re: 92 Gsxr 1100 rear brake bleeding question
I've just done the rear caliper on my 91 1100, they should be pretty much the same.
I've found that the vacuum pump is good for getting things started and then I switch to the normal pump lever, crack nipple, close nipple, pump lever routine.
I found the vacuum pump to be a bit misleading as theres still bubbles that get drawn in around the nipple threads. I only used one bleed nipple on the rear caliper?
I bled the system fairly quickly after using the vacuum pump to get it started.
Not quite sure from what you described how your bleeding the system exactly?
Liam
lem123 is offline
post #3 of 6 (permalink) Old 04-19-2019, 06:03 AM Thread Starter
dontilgon1's Avatar
I was using the hand vacuum pump but wasn't drawing any fluid but I just ordered a air vacuum pump so we'll see. Worse case I'll order a rebuild kit for the master. Thanks for mthe reply.
post #4 of 6 (permalink) Old 04-20-2019, 01:29 PM
86gixxxer's Avatar
i'm not sure what problem you are experiencing? bleeding brakes is straight-forward, and yes, you do need to bleed both caliper nipples. hand-held vacuum pumps are excellent tools.
is the system pushing brake fluid? if not, sounds like you might have a defective master cylinder.
86gixxxer is offline
post #5 of 6 (permalink) Old 04-20-2019, 02:02 PM
If the master cylinder and caliper have never been apart, they need a rebuild. Disassemble both of them, clean everything and re-assemble. If there is any visible wear on the rubber parts, replace them.
If the hose is original, replace it. Suzuki's suggested replacement interval was 2 years. We usually go longer than that but 2 decades or more is pushing it.
You bleed from both screws. Bleed the closest one to the caliper fluid inlet first, then the other, then the first again. Etc.
javadog is offline
post #6 of 6 (permalink) Old 05-02-2019, 01:34 PM Thread Starter
dontilgon1's Avatar
Thanks Picked-up rebuild kits for brake and master. Ill post some pics of rebuild
Impossible to bleed rear brake Kuprito 07-08 GSX-R1000 19 10-05-2013 05:05 PM
Rear Brake Problem GSXRaw SRADs (97-00 600 and 96-99 750) 3 05-15-2007 10:45 AM
Rear Brake Bleeding problem.... RaptorsSky123 06-07 GSX-R600/750 5 01-27-2007 07:00 PM
Rear brake question Blipstein Track Days 16 09-06-2005 04:27 AM
2002 GSX-R Rear Brake Bleeding Stretcher Mods & How To's 3 07-15-2005 10:59 AM
